W213/C238 inner front right tire is getting 'worn' by something
anyweb
Sweden
www.niallbrady.com
c238,w120 (diesel)
hi
on my C238, I had to replace the two front tires as the right most tire had severe wear on the inner wall, as if some metal was cutting a groove into it, so much so it split the tire and i had to get two new replacements,
when it happened i asked my indy why it was happening and he guessed there was not enough air in the tire even though i had pumped them up to the recommended level on the inside of the fuel cap,
fast forward a year and the replacement tire on the right side only, is exhibiting the same behaviour, i can see the groove being 'burned' into the tire, but i cannot see anywhere on the car that could be causing it, it's no where near as bad as it was on the previous tires which were replaced but i can see i'll have the same problem soon enough if i do nothing,
do any of you have any ideas please ?
cheers
niall
Any speed cushions in your regular route and do you cane it into the bends?
ajlsl600
france
Interesting. Had have same on frons on my w168 no cuts but bad wear on inside of front tyres tracking done 2x still same. I watched em do it. Now at end of 2nd year I putcfrontctobrearcand spin em on rims 2 new on front. No accidents in 12 Yr.
anyweb
anyweb
Sweden
www.niallbrady.com
c238,w120 (diesel)
Any speed cushions in your regular route and do you join it into the bends?
lots of speed bumps but i go over them slowly, not sure what you mean 'join it into the bends' ?
“Cane it” bit of autocorrect nonsense
Speed cushions should not be straddled as they ruin the inside of the tyres and regularly crack rims. 1 wheel in the gap and the other over the middle of the cushion
Benz17
london uk
E350d Amg Premium Saloon, Cavansite Blue, 2017
Are the tyres Goodyear F1 run flats
anyweb
anyweb
Sweden
www.niallbrady.com
c238,w120 (diesel)
it's a mix of tires, the first set to get the problem were Goodyear Eagle F1 Asymmetric 3 245/35R20 95Y NA0 FP and now i've noticed it on my Firestone Potenza S001
I've booked tracking on the car tomorrow, let's see does that help...
Benz17
london uk
I had the issue on my GY AS3, inside edge torn to the cord, were run flats, many have also had the same issue on these tyres in Germany, there is a long thread on it.
But if it has also happened on another make, then could be a problem with the car.
Benz17
london uk
This was my danage
Benz17
london uk
My Goodyear was also the same size as yours, I went to WIM to get the tracking checked after changing the tyre, Joe there said there was not a lot of adjustments needed doing, he blamed the run flats for the damage. This occurred 18 months ago.
This week have changed all RF GY, to NRF Michelin ps4s. It has made a big difference to the ride quality.
anyweb
anyweb
Sweden
www.niallbrady.com
c238,w120 (diesel)
so i went and got the tracking done, the tracking guy said it was way off on the front right/back right, so hopefully that was the cause !
Benz17
london uk
Glad it all got sorted, now you will have to keep an eye on it.
anyweb
anyweb
Sweden
www.niallbrady.com
c238,w120 (diesel)
i sure will ! thanks for all the replies everyone
Tel: 020 8863 9233
