lordgaz
- Dec 8, 2015
- Location
- Herefordshire UK
- W220 S-Class S55 AMG 2000 / W220 S-Class S55K AMG 2003 / W163 ML270 / Jaguar XJR X350
Hi All
If you have seen some of my other posts you will know that I have experienced recently a failure of my W220 due to water ingress through a blocked reed valve in the bulkhead.
reading this old thread from Chas, it is suggested that there was a recall to add an emergency valve
http://forums.mercedesclub.org.uk/showpost.php?p=186837&postcount=1
My vehicle has just spent some expensive time with a local MB dealer who has fixed some damaged wiring in the passenger footwell, and I asked the tech if an emergency valve had ever been fitted -
He said there was no recall, saying it was normal to just remove the bung.
Does anyone have any solid information about this - was it a recall, advisory or just an option to fit an emergency drain valve? The car is full mercedes service history - so if there is any chance I can put this issue (and some of the cost) back to them, it would be very helpful - But I would need solid information...
Many thanks
Gaz
Many thanks
Gaz
