Richard Moakes
- May 19, 2002
- Location
- Newton Abbot, Devon, UK
- CL500; ML500
A brake service is likely to have moved the cables for the WSS, if any of the wires were weak then it’s probable that was the final straw and caused them to fail.
In my experience a failed WSS on a 216 causes the car to melt down with lots of warnings but it does not cause a failure to crank/start. Knowing how fragile these things are, I did use the parts cannon and replaced all four, so as to get to a known baseline.
With your car, using the parts cannon hasn’t worked so far, and it’s unlikely to find the problem going forward. What you need is a good auto electrician with a decent scan tool, high end Autel or preferably Star/DAS who can look at live values in the drive authorisation chain and then test the wiring with test lamps and meters.
Intermittent faults are never easy to find but are often caused by corrosion in wiring or connectors hidden away under junction boxes or relays or in places difficult to get to. Look out for green powder anywhere wiring connects, it will permit voltage so can’t be accurately tested with a multimeter, but try putting a load on it with a light bulb and you will find it doesn’t flow current so can’t engage relays etc.
