W221 S350 transmission not shifting properly.
ircj
Mercedes S350 W221 2011
Hey everyone, hope you're having a great day.
I've bought a Mercedes S350, 2011 model. It's my first Mercedes. It's been a great car so far. A few niggles here and there but it's generally been fine.
I've started to notice an issue with the transmission recently. I'll describe the symptoms below.
- While driving, the gearbox starts behaving a weird. There is usually some RPM slippage. When I try and accelerate, the rpm dial moves up a little bit without any change in speed.
- I'm unable to change the gears using paddle shift.
- The performance is also very limited, increasing speed very slowly.
- Only way I've found so far to drop gears is to slow down so the car is forced to drop down the gears
- When accelerating back up, it shifts gears as as if it's almost forced to do so, at about 3000 RPM. It holds onto the gear until it has to change, rather than a control unit telling the gearbox to change gears.
Restarting the car fixes the issue.
I've had the gearbox serviced in April. If anyone can shed some light on this issue, I'd be grateful.
Thanks in advance,
Collin
Thanks in advance,
Collin
Welcome buddy , sounds like a nice car . It’s in limp mode because of a fault .
Can you return the car to the dealer to fix under warranty?
If not it’s Mercedes specialist time , there will be a fault code logged .
Where do you live so a specialist can be recommended? Update your user details with location
Was the gearbox service done by MB or a specialist?
I
ircj
Hi there, thanks!
I love the car, it's supremely comfy and I can do a lot of mileage with ease.
I bought it from a used car dealer and he's already fixed some issues for me. I want to diagnose the issue first before getting in touch with them.
I got the service done by Hampshire Service Centre. I'm based in Swindon.
I've booked a diagnosis with MB&B in Cheltenham next week. Fingers crossed it's nothing major.
Hi there, thanks!
Let’s hope so , let us know how you get on . If you are at all handy , it helps to have an icarsoft code reader for these cars . You can probably pick one up for £100 on eBay or here on the forum sometime
BS4291
S350
Hi there, thanks!
Just wanted to know if you resolved the issue and what was the problem?
I'm having similar issue with mine at the moment
Bill
Bill
MB specialist time buddy
BS4291
S350
Thanks,
Yes will be taking it to my local independent MB specialist.
Is the gears changing at 3000rpm a common limp mode function or is it something else. I have no EML or warning lights on.
Reverts back to normal once switch off and restart the car.
Thanks,
Yep 3000rpm limit is limp mode .
Let us know how you get on with the specialist. Good luck
NeterKhertet
S320CDI L (W221) 2008
Does anyone have any more information on this issue?
I note both the posters have never returned and commented on the issue at all.
I'm having what sounds like the same issue, I have a couple of questions related to it.
01) Are the wheel speed sensors "related" to the transmission shifting or the manual shift buttons, because I know at least one of mine is on the "fritz" - possibly more than one, I've never replaced any of them and don't know when they were replaced so it is probably time to do all four.
02) My thought linked to above is if it cannot detect the wheel speed it may not know exactly when to shift hence the issue.
03) My gear selection buttons don't work, but all the other steering wheel buttons do? could it have something to do with the connection in the steering wheel?
04) I've scanned my car using a TopDon TopScan Pro - and it has no transmission faults, plenty of others lol, but no transmission! speed sensor on Drivers Side Rear comes up (RHD car) and intermittently one of the others does as well front passenger I think it was - so think time to do them all is a good idea.
05) Could the gearbox need a service/oil change, could that cause these issues? and also my car is a 2008 (Pre-facelift) S320CDI L does this have the torque tube that needs to have the oil replaced as well, I've seen a You Tube video showing how to do both - not sure if I want to tackle it myself or pay someone any advice?
Any experts on here with any advice on these issues? I'm just assembling the parts I need to do some of this myself, need to get some glowplugs and change them as I have a starting issue on the first start each day, need to let it crank fully once then on next turnover it starts right up (on colder days might take two) - and don't think they have ever been changed.
At the moment my list of parts is:
6x Glowplugs - leaning towards Bosch ones - anyone have any advice on best ones to use?
4x wheel speed sensors (Do need some mounting bolts for them as well)
Anyone know any other parts I might need for the above? I WILL report back but it might take me a while as I need to do this maintenance whilst keeping the car on the road, so have to schedule (really need to get a second car lol) so I can do the maintenance over a day or two without disruption
If anyone has other info or advice, please share and I will do likewise as I discover more and work on the issues.
