W245 B170 Starter motor and other errors
SunnyDee
West London
C250 W204 Petrol Coupé
Hello team,
Been a while since I posted something up. I hope you are all keeping safe during this horrible time?
My dad old B170 (2006) is throwing up some errors on his dash:-
1. Power steering (red)
2. ESP - Visit workshop
3. Run Flats indicator unavailable
4. And now starter motor not functioning.
Any ideas?
Thanks,
Sunny
What's the battery voltage?
SunnyDee
SunnyDee
West London
Here is a sort youtube video
SunnyDee
SunnyDee
West London
It's probably gonna be low right now as the car been standing still for three weeks.... but how does one find out without a voltage meter? (there's a hidden menu somewhere right?
bertb1
C220 amp sport 2013
I’ve had the esp and the run flat problem on mine and it was the sensor and hub ring
Its in the garage at the minute , it went in yesterday but the wrong part turned up
Finding it hard to get parts delivered from Mercedes
Yes + 1 for dead battery, did you jump start if for the video?
key to Pos 1, the reset button 3 times will show batt voltage.
I don't know your model, I'd use a meter - they're cheap enough. 12.6v is what you should be looking fro with engine off and >14V when engine on.
Does it start?
SunnyDee
SunnyDee
West London
Good luck and keep me posted please, but don't know why the power steering would go and car won't start up any more.
@Blobcat @AMF Mercedes Tnx :)
SunnyDee
SunnyDee
West London
@Blobcat the car battery is 11v (but the car doesn't start so I cannot check if the voltage goes up.
My W204 Coupe says 14.8 and goes up when I start him up...
11 is pretty low, do you have a booster pack or can you try jump starting it?
Flyinspanner
Ruislip
Battery sounds like it’s dead. 11v is way too low, and will also cause weird fault codes as sensors will be ‘seeing’ wrong voltage.
It should be 12.7 engine off.
Look at eurocarparts and try SALE60 code for discount on a new battery.
If it’s an 06, look at the age of the battery - maybe a sticker or stamped on terminals, at 5 yrs they are ready for the bin.
Check Grangemouth prices, they deliver. Or Tanya online.
SunnyDee
SunnyDee
West London
Hello all,
RAC guy turned up :( and it turns out the starter motor has gone....
Even he said its too much work to be done as the engine needs to be dropped out... (why the heck did Mercedes put the engine at the bottom of the car???
ajlsl600
france
:( We have done a few, its not horrendous, engine can be dropped slightly to gain access, doesn't need to be removed completely.
so much for progress my ng tf two spanner 2x 9/16 bolt 1x 7/16 nut 5 min starter out ,5 min back in .i would keel haul the P that designed drop/remove engine. and IF i had the the sense/memory i would never buy a car built in such a way . I did BUY A W168 so prob have that to look forward to. petrol can ,just be done from top, my 170cdi cant ..
ZZZZ
As above ^^^ :)
I've had mine done in August 2017.
The engine position is actually a very clever safety feature, for a small car - in case of a frontal collision, it goes under the car, rather than smashing into its occupants.
ajlsl600
france
As above ^^^ :)
if that clever?? design a hatch inside the f car so one can get at the service items !!!!
SunnyDee
SunnyDee
West London
  • #17
so is it worth doing then? Also, I have the power steering problem as well? that won't be related in any way (Am I correct?)
I woukd be checking fuses and power supplies before condemning the starter motor. Sounds potentially like a a midi fuse has blown
ajlsl600
france
as above ,check EVERYTHIN before dropping motor ,i would need a crate of good whisky if i dropped the motor ,for the sake of a fuse or minor drama........
SunnyDee
SunnyDee
West London
  • #20
haa haa very true... lol... and i do miss a stiff drink... being locked down and missing my friends is sooooooooo boring.
