Warning lights
bertb1
C220 amp sport 2013
Morning all
I had to go for a MRI scan this morning I set off and about 3 minutes into my journey I got this flash up on the dash
I got the the hospital and had the scan and when I came out and driven home it was fine no warning lights
Can anyone shed any light of what it could be
Thanks in advance
bertb1
bertb1
C220 amp sport 2013
  • #2
ABS sensor dirty or on its way out or the reluctor ring it looks at had something stuck to it .... :confused:
As per above is a common cause
bertb1
bertb1
C220 amp sport 2013
It was abs and run flat message
bertb1
bertb1
C220 amp sport 2013
Is the ABS sensor replacement easy or a big job ?
ajlsl600
france
grand its sorted. nice if message just said that.!!
bertb1
bertb1
C220 amp sport 2013
A grand ?
bertb1
bertb1
C220 amp sport 2013
I’ve tried to upload a video but having no luck
surely the icon on the right is the 'traction control'/ESP ...... would be better with a less wobbly photo :rolleyes:
It does look like ESP has been turned off...
bertb1
bertb1
C220 amp sport 2013
bertb1
bertb1
C220 amp sport 2013
bertb1
bertb1
C220 amp sport 2013
bertb1
bertb1
C220 amp sport 2013
Thanks all
It was alternating between these 2 messages
umblecumbuz
Wales and Gozo
Normally not serious. If you have a scanner that gives live data it can be easily pinpointed. I know that may not be possible right now, but if you were considering getting one - now is the time to order.
Thanks all
the indirect TPMS also uses wheel speed so also points towards ABS sensor/reluctor ring.
If the message has gone, it might have just been a dirt/etc Obviously if it comes back on again you need to look further into it.
bertb1
bertb1
C220 amp sport 2013
  • #19
The car as been stood still for a week
Could a bit of rust from the disc cause this ?
bertb1
bertb1
C220 amp sport 2013
  • #20
I’ve had a quick look online and the sensor is around £70 and the ring is even cheaper surely it can’t be over £900 in Labour
Can it ?
