water loss?
lolweir
Sarf London
mercedes v230 petrol/Lpg
on my v230 i loose water but no sign of a leak.Also theres a misfire when it starts from cold, could it be the head gasket?...the oil is clear of any mayo in the oil cap, and coolant is clean also.I've changed the plugs and leads,water pump, radiator, and thermostat...is there anything else to check before going down the head gasket route?
Cheers.
Steve@Avantgarde
Bristol/Somerset
C43 AMG PP/NE, SLR McLaren Roadster, SL55 & C32AMG
Sounds like a headgasket. If the gasket has failed across a water jacket into the cylinder then you wont get oil in the water and the classic mayo signs.
Compression test is the next port of call.
Another thing you can do is set the coolant level, get the engine nice and hot, before leaving it overnight release the coolant radiator cap and leave it off. This will release the pressure in the cooling system that will force water into the cylinder overnight. If it doesnt misfire in the morning or to a much lesser degree than usual then you will have a HG issue for sure.
L
lolweir
Sarf London
I'll give that a go today....what do you think the average cost of repairing the HG at a garage. I know it's dependant on their hourly labour, but ball park figure.
Thanks for the help.
L
lolweir
Sarf London
I'll get a compression test done and cross my fingers.
Cheers for advice,
DIYMAN
Nr. Harrogate
E270cdi/53 plate/2.7l 5cyl.
The overnight test Steve mentions proved the HG failure on my old 230E.
Always worth trying the K seal it works very well on many leaks and the best one on the market :D I have used it and its been god for 3 years now.
Frontstep
T210 320cdi
I think the new lenses will end the typo's !!!
gregdw
Radcliffe Manchester
V230 1997 + VW Touran dsg7 +A170 2001
yeap I used steel seal and did 1500 miles before min was toast lol,
defo sound like gasket
