Water penetration in footwell - 3003L 1992 W129
Status
Not open for further replies.
PeterG
During our recent tropical weather I have noticed my drivers footwell is pretty wet. I checked underneath and so no obvious hole although most of the underside is covered with panels. I also checked the door frame which is fine. The firewall on each side is dry so it is def coming from below. Any ideas guys.
Thanks Pete
P
PeterG
Thanks Andy I will have a look when its pouring with rain again.
Pete
kes 300
south uk
i had the same problem the seals at the  top of the door pillars are leaking  ( dripping onto seats& floor) where the hardtop meets .as my drive is on a hill i parked it uphill  so that the rain did not run of the roof towards the windscreen this made a difference ,unfortunatley i found out  that the water in the footwell was due to a buggered heater matrix
gtmoore
Just a thought and not really sure if it's the same on Mercs as I drive a BMW (I'm here for someone else!) but I had a 5 series that suffered a wet footwell and this was due to the drainage holes in the sunroof channel becoming blocked - this caused the water to backup and run inside the headlining, down a door pillar and into the footwell.
HTH
Status
