Ted Schrecker
Whitley Bay
2003 SL500
Hello all, I have been planning to have my recently acquired (February 2019) 2003 R230 Waxoyled to prevent corrosion, none being evident at the moment. However, although my manual indicates that the underbody of the vehicle needs to be inspected for damaged areas, which 'need to be re-undercoated', it then says: 'Your vehicle has been treated at the factory with a wax-base rustproofing in the body cavities which will last for the lifetime of the vehicle. Post-production treatment is neither necessary nor recommended by Mercedes-Benz because of the possibility of incompatibility between materials used in the production process and others applied later.' So: Does anyone have further knowledge of this, or experience with Waxoyl or similar processes, or recommendations about specific providers? With thanks, TS
ajlsl600
france
i removed all my inner wing trims ,power washed and when dry waxoiled everything on my r230 Vdoz,sadly,now sold on. other areas i plastered in wd 40 OR acf50,different areas. thus i had zero rust on any of the wheel arch lips . i did this every summer during a dry week.
Have a read up on Dintrol treatments , I have used them in my CLK's rear subframe and rusty bits . Also ACF50 is worth having in your garage for general yearly spraying of brake pipes and electrics
flowrider
SL500 (R230)
The only area I have waxoyled are the rear wheel arches.
SL63 Mark
The South
R231 SL63 AMG
As above I waxoyl the rear wheel arches every couple of years. Works for me, no rust yet. Other than that, no point I would say. The only rust you see on 230s is bodywork, which the waxoyl wouldn't touch, e.g. boot lid, and below the rear window where the seal meets the body. It's not a like a landrover Defender where you have good access to the chassis and can inject the waxoyl to some effect.
umblecumbuz
Wales and Gozo
I was shown a tip with Waxoyl, which really seems to work.
Having used the stuff for years (I buy in gallon cans) I was shown how to make it more effective. Heat it on a stove until hot and runny like milk. Heat the Waxoyl gun also. I use a camping burner for this.
It sprays like runny paint, with a strong heavy mist. On my old 4x4, which has chassis rails, I can spray into one end and watch a satisfying mist exit at the other. After about twenty minutes it starts to cool in the gun and thicken up, but by then I've done the whole car.
Checking results, it's obvious that this method is way ahead of spraying it cold.
Ah... This brings to mind the waxoiled cat story....
Er ... the cat story?
The following is a blog from a chap who applied waxol to his car,
True story that has been on the LR forums for a few years... anyone who's had dripping Waxoyl in the face while DIYing the job will appreciate this...
Waxoil….
I really wanted to get some of this into the Land Rover's chassis before I started using it. I had gone to halfords and bought 2 gallons, and knocked off work early.
I also had the real benefit that SWMBO was out so I had since 3.00pm been shoving the 2 gallon cans into the sink with near boiling water. I should have known things were going to go “slightly wrong” when I started.
I decided to use a Waxoil gun and my compressor, I had the propane burner on in the workshop since 3.00pm flat out and it was like the sahara, in fact it was so hot I decided a T-shirt and shorts was the dress code.
Grabbing some white spirit to further thin the waxoil I entered the kitchen and unscrewed the waxoil lid.
Thhhhuuuumpppppppp !…grwat big snotty big dollop spewed out over the kitchen worksurface... no probs I thought, ...I’ll sort that out when I’ve finished, as I might make "a little bit more mess yet".... glad she's not in.
Clutching hot waxoil injector thingy, part filled with waxoil and mixed with very very warm white spirit I squirted and soaked the chassis blasting away, and also practising holding my breath as it went misty in the workshop.
1 Gallon later I was nearly there, I was at the rear cross member, with yet another huge refill.
I ought to point out that I had also decided that at some of the angles I was at pulling and holding the trigger was a pain so I had devised a cunning lock of an elastic band on the trigger so that I could let it do it things whilst it sprayed away. Shove tube into hole and pull trigger… lock and waggle etc.
Enter the cat.
It sat there and looked at me the way only a cat can... it sniffed (unapprovingly) the dripped waxoil, and I said…
“Huh, you don’t want to be in here matey, this stuff will stick to your fur like brown stuff to a blanket”……and at that very point the jammed on tube extension came off the gun.
Could I release the elastic band round the trigger ? Could I XXXXXX.
The gun squirted warm waxoil/white spirit out at a force never so far experienced, one particularly good jet hit the cat, who bolted, knocking over the 2/3 empty (1/3 full!!) can of hot waxoil/white spirt mix, which flowed oh so well under the landy, and into my clothes T shirt and clothes and skin areas exposed..., but I was still fighting with the hot octopus trying to switch the damned thing off, but I failed, I was saved when it ran out.
Just when I thought nothing could get worse than lying under a Land Rover with waxoil soaked clothes, waxoil dripping onto my hair and face, and running into my ears... Some waxoil drpped onto the lead lamp... ping... Blackness.
It also pinged the fuse for the lighting circuit, getting myself out of the underneath of the landy proved friutfull, in that I knew all the places that waxoil had “leaked”.
Removing dripping clothes I entered house in “minimal Clothes” to resolve fuse prob, when Lights went on I saw the cat…
I AM GOING TO DIE IF SHE SEES THIS !
Here Puddie cattie……
This did not improve the sink/kitchen area one little jot, .....ever tried holding a 'waxoiled cat' in a sink with water and rags, and especially when cat does not enjoy it ?
1 hour later cat was scrubbed and very peed off with me, I’ve had 2 baths, and also cleaned the bath it seems that the bath will not be rusty...scrubbed kitchen floor, sink, worktop
Will she notice?
Cat stinks, garage sticks, alley way stinks, I stink, kitchen smells of lemon washing up liquid, which strangely we seem to nearly be out of, floor stinks.
She will be back any minute [gulp]. Nice job on the Landy tho....... :)))
...later that evening...... Alleyway door closes and SWMBO walks in..... "have a nice time dear ?......." "what the HELL is that smell ?"
"Smell ?....er do you mean the waxoil ?" "Is that what it is - its disgusting" "Er..really"....
"yes really, the alleyway stinks, I mean I could smell it when I got out of the car..."
"er...really ?"
"yes, Really, I mean its stinking everywhere out, its even permutated the house " "really"
"yes really and [ picks up cat - I look away at telly and pray]...and ....good grief even the cat smells of it its ....[ at this point the cat growls.....probably hand enough of being "handled" during the evening...]..."WELL if your going to be like that madam you grumpy old thing" ...[places cat down firmly - cat grumbles some more].. cat exits still grumbling
"Charming... well... Anyway, have you finished?"
THOUGHTS...............
I've got away with it...."all done"...I've got away with it...."think I'll have a beer"...I've got away with it....I've got away with it...."Would you like a glass of wine ?"....I've got away with it....yippee....I've got away with it....and
SHE'S GOT THE HUMP WITH THE CAT TOO - NOT ME !!
Beer.... Bed.... RESULT....... !
But a bit close for comfort......far to close
