What lubricant/grease for sunroof rails?
moj91
Northamptonshire
W213 E400d-T, W204 C250CDI-T, W220 S320CDI (AMG Kit), W168 A170CDI, W210&W124 OM606...
Whilst im cleaning the pan-sunroof drains tomorrow (see other thread) i could do with lubing/greasing the sunroof rails. What should I use? There seems to be quite a lot of different suggestions on the net, with various warnings of causing damage if the incorrect is used.
Thanks!
Craiglxviii
Cambs UK
I find that dry lube spray PTFE works v well...
DREAMER NO2
W124 2.6E M103 1989
As above,, but i first clean off the old crud first before you put the new lube on to the rails . I used WD40 only to brake down the old lube thats on the rails then wipe it all off clean .I then spray in the new lube .
moj91
moj91
Northamptonshire
Ill give the GT85 a go then! thanks!
