What wax/polish???
Dwg_23
Stoke-on-trent
2010 C250 estate
Hi gents, just wondering on your views to the best wax/polishes to use?
I've always stuck with auto glym super resin polish! Any views??
antijam
Gloucestershire
2003 SLK320
I'm with you on the Autoglym Super resin polish. Easy to use and very good at conditioning the paintwork for subsequent waxing. For that I stick with Autoglym and use their High Definition Wax. Expensive but effective and quite long lasting.
D
Dwg_23
Stoke-on-trent
2010 C250 estate
So you have to wax it after the resin polish? I've only used the super resin polish in the past! Can you tell the difference after you use the high definition wax then?
antijam
Gloucestershire
2003 SLK320
No, you don't have to. The SRP claims to provide protection from environmental contaminants, which is traditionally the role of the waxes.
But - yes, you can tell the difference after the HDW. The gloss is deeper and water shedding is visibly better.
D
Dwg_23
Stoke-on-trent
2010 C250 estate
Might treat myself to a pot, like a good shine!! Thanks!
CPShines
London
C220 CDI Coupe 2002
Autoglym here too
A couple of times a year I use SRP followed by Autoglym Extra Gloss Protection. In between times I've started using their Aquawax which leaves almost as good a finish as the EGP but doesn't need a dry car, so it's quick to apply. Very happy with Autoglym so far.
FIBAMAN
TYNESIDE
C180,C180,E300TURBO DIESEL
If you want the easyest result, try the new stuff from Armorall.
So easy to apply and no graft to polish up.
D
Dwg_23
Stoke-on-trent
2010 C250 estate
Alot of people rate autoglym by the sounds of it! I've used it alot on my last car,
Just brought a merc and wanted the best wax for it, might stick with srp and try the high deff wax too!
whitenemesis
CLS55 AMG '05
Collinite 915 has been my wax of choice. Very good durability. The new stuff from Meguiar's, the Ultimate range gives excellent results as well, even in direct sunlight. Carlack69 do a brilliant sealant, so easy to apply and you can even add it to the wash solution.
I have gone over to Autoglym and yes so easy,,, I tried to buy the wax but Halfords down here did not keep it :(
D
Dwg_23
Stoke-on-trent
2010 C250 estate
Hal-frauds????!! Don't shop there! eBay everytime! Saves loads of pennies!!
Fleetwood
Horsham, West Sussex
2005. SL350
A friend of mine makes car polish ! Always try and get a few gallons as samples !
He sells it to the F1 teams and Ferrari UK and Aston Martin so it's got to be pretty good and for me it's free :lol:
D
Dwg_23
Stoke-on-trent
2010 C250 estate
Go faster F1 wax..... Sounds good to me!
