Where is water pump relay
Adrian 27
New Registration
E class 212
Fault. Code p 2600 water pump open circuit. Changed pump but still same code so please where is the relay. Spent hours looking at diagrams so help much appreciated
Botus
S500/2010/500
the exact model of car and engine would help... or better vin
EmilysDad
Bury Lancs
ML350
Wow. An electrically operated water pump for the engine.
What a wonderful fuel/emissions efficiency design.
Electric engine water pumps have been around for a while. I suspect the OP's water pump is an auxiliary water pump for the heater when parked up or an electric pump to circulate coolant for a set time after the engine is switched off to prevent localised over heating.
And while not technically electric, the water pump on EmilysMums Citroen doesn't get driven all the time .... a motor moves a pulley to drive the water pump when required (I believe its a BMW engine ??)
onefortheroad
uk.
Me -2019 GLC 350 coupe AMG line. Mrs- 1.2 vauxhall Corsa 2021 ,orange with a black roof. .
212 e class is it ?
ajlsl600
france
Saving 2 ltre a Yr. And complicating everything. They will be disengaging drive on downslopes next.
malcolm E53 AMG
I assume it’s the OM651 - did the garage replace with a genuine MB part if not aftermarket are known to be troublesome?
ajlsl600
france
Made of plastic.. Tells me all.
EmilysDad
Bury Lancs
ML350
Coincidentally .... the original water pump on EmilysMum's C3 was plastic. Needless to say it leaked. The new OE replacement was ally .... :rolleyes:
ajlsl600
france
A step backwards today is often a good thing. Says plastic was dtf and ur alli is, Yr payin, a better job
supernoodle
E220 2005 2.1D
If the part shown by malcolm is what is on the OPs car, there are no electrical connections. In which case if you have an open circuit fault, changing the pump won't fix that. It shows as vacuum controlled, in which case there must be an EVRV (electronic vacuum regulating valve) somewhere. An open circuit fault for that would make sense.
First job for OP identify what's fitted.
supernoodle
E220 2005 2.1D
P2600 is specified in ISO15031 2005 as Coolant Pump Control Circuit/Open, it is not manufacturer dependent.
A W212 should be complying to the specs, so code reader won't matter.
Tel: 020 8863 9233
