Which mobile phone originally was fitted to my CL55 AMG 2000 reg?
davis810
Ive recently bought a CL55 AMG W215 2000 reg.
And it doesn't have a mobile phone.Im trying to find out which mobile phone came originally fitted?Ive tried Nokia 6210 and 6310i but they don't fit.
Is there a number on the cradle,, that should be checked,,it might be underneath the 6150,6210 and 6310 were all current then.
You can buy a Nokia cradle cheap on Ebay
Chas
Scotland
S320
Whats the part number on the phone cradle ? Mine is a 6150 cradle but 6210 works in mine. Does it charge up , is it in the armrest?
D
davis810
I can;t see a number on the cradle but.There is a cradle there with no phone.Ive tried 6310 and 6210 but neither fit.
Chas
Scotland
S320
Can you take a photo of it? Probably a Nokia 6150 ? £2 on e bay :D http://cgi.ebay.co.uk/Nokia-6150-Mo...ones?hash=item3ef76f6b20&_trksid=p3286.c0.m14
http://www.detali.ru/cat/oem_mb2.as...GA=722.636&CT=F&cat=65N&SID=82&SGR=336&SGN=14
D
davis810
I'll take a pic and post it back on this thread.
Thanks.
Is it easy to get and change the cradle in order to fit another model of mobile?
There is a very limited range for that year
Chas
Scotland
S320
You might be better getting the Mercedes MBU 1000 blue tooth module
http://www.viseeo.com/ugC_ShowroomItem_Detail.asp?hidPage1=1&hidShowID=8&hidClickNum=Y
http://www.itjustworks.co.uk/downloads/mbu1000_manual.pdf
About £175, and you can use just about every phone, 2 mins to install/plug in. Check the list above
MB cradles are ridiculously expensive, and you would probaly be limited to Nokia 6210, like me ! The bluetooth module above is well worth it if you want to use a more modern mobile.
Make sure you have taken the small rubber plug out of the back of the 6210. There is a small round socket which plugs in to the cradle
D
davis810
Ive taken a couple of pics.If anyone has any ideas by looking at the pics it will be most appreciated.
D
davis810
And this one of the connecter
That is one of the phones that you hold to talk,,it takes what ever plugs into the end cable
I would change it to one of these
D
davis810
Thanks.Is it easy to change?What model of phones are in the pics?
Nokia 6310i I also use a 6210 and a 6150
Chas found you set up,,but you cannot identify the phone lead from it
Chas My MP3 came today :D:D
Have you installed it Malcolm ?
No I have ordered the extra wires, and will include it in the ring,,it will go into my glove box and I can plug into the phone module under the center box,, so much easier on mine :D:D
D
davis810
  • #19
ive just received second hand cradle b6 787 5846 with a nokia 6220.
The plug that is in my car is the same male connector that would plug into the cradle.But the problem i have is that the actual plug size is to big.
Is there anything i can get or change?
Also do i need to take out the existing cradle?thats in my previous pic
OK I am with you now,,yes the cradle in the car was a plug underneath or the end cover comes off , unplug it there and plug in you new one
www.ckinsurance.co.uk
