Widest tyre size possible on 19"AMG rims CLK320 2005
Mickey42
IPSWICH, ENGLAND
2005 CLK 320
I`m currently on 235/35`s all round but the rears need replacing. I was wondering if anyone knows how wide can you go on the rears? I`d like 255/265 if they would fit. Thanks.
Lit.91
GB
MB
That sounds very narrow for rear wheels. You need to know the width of the alloy.
Bubble
Braintree
www.motacar.com
E350 Coupe CDI / Land-Rover Discovery 4 / Nissan Skyline 650bhp R.I.P.
I ran 275/35X18 and a 5mm spacer on the rear of a 2007 CLK with the original AMG wheels, though it does depend on what offset the wheels are.
M
Mickey42
IPSWICH, ENGLAND
2005 CLK 320
Thanks guys, I`ll measure up the width of the wheels tomorrow and feed back.
M
Mickey42
IPSWICH, ENGLAND
2005 CLK 320
Finally looked at rim size today 8.5j. Thank you and I`m getting tyres this weekend just not sure how wide I can go.
M
Mickey42
IPSWICH, ENGLAND
2005 CLK 320
Hi Guys, have to replace rear tyres this week, with the dimensions I have given can I have any advice on what I can achieve? Currently on 235/35/19 but I`m hoping to buy 255/35, anyone tried this?
Thanks, Mickey
AMGeed
Poole, Dorset
S204 C180K
Have you got 8.5j all round Mickey?
Here is a 19" CLK alloy with the correct size tyres front and rear. They are staggered rims though with 8.5j front and 9.5j rears.
Scroll down the page and you can see the suggested tyre sizes
http://www.alloywheelsdirect.net/mercedes_alloy_wheels/clk_class_209_alloys/19_amg_iii_wheel_302
255's are fine on a 9.5j alloy but I don't know about an 8.5j
Try entering your existing set up into this configurator, then what you want to use and see if its possible.
https://www.willtheyfit.com/?width=...2=40&wheel_size=17&wheel_width=7-5&offset2=48
rf065
Grossbritannien
Your tyre sizes are all wrong, my CLK on 17" rears was on 245/40x17, how have you ended up with 19" at only 235?
Maximum for an 8.5" rim is 255 but 245 is optimal.
Whatever you fit must match the overall diameter of what you remove. If it doesn't you'll have issues with ABS, ESP and cruise.
If you currently have 235/35 then 255/30 is as close as you can get (1.8% smaller overall).
You cannot fit 255/35.
The difference in diameter front to rear will cause issues with ABS, ESP and cruise.
The closest you can get is 255/30 19.
rf065
Grossbritannien
Do we even know what size is on the front? Or the width of front/back rims?
JBell
Torquey
C350 CDi Estate (GAD Edition)
Correct, 255/30 is the right size
A 255 will fit on an 8.5" wide rim, that is the max width for that size wheel
rf065
Grossbritannien
Yes in his original post he tells us. 235/35 all round and the title says 8.5" rims.
Not how I read it, only says rears on original post, no mention of whats on the front. Certainly doesn't say all round anywhere.
