Window master switch
Andrew63
C250 estate 2016
Unfortunately the wife managed to snap off one of the window selector switches. Mercedes no help at all
I couldn’t believe I could get a replacement switch selector on eBay from China of course! £7.50 it took 3days to get here and fitted a treat I cannot see any difference.
Hello and welcome
A
Andrew63
C250 estate 2016
Thank you
I will have to get to know how this forum works l better update the info
davemercedes
Glos
Hello and welcome
A.J.
Norwich. UK
Hi Andrew, welcome to the forum :)
A
Andrew63
C250 estate 2016
Thanks guys
we have a s205 250d 65 plate just had a software update
anybody know what it’s for other than emissions?
Ming 666
2016 C350E
Hi. Can I ask what kind of switch it was? I have the same problem with my C350. The replacement from ebay is cheap but it doesn't look like a push fit https://www.ebay.co.uk/itm/184072631287?ul_noapp=true
A
Andrew63
C250 estate 2016
Indeed. the master switch assy with the mirror selector.
From the picture on eBay you cannot tell if it’s the same. The selector the wife broke was the offside front switch. It left two pieces of plastic within the main body. With careful teasing they came out. The new switch selector came with a replacement spring and plastic fitting that I guess makes the movement silky. If you’ve lost the original spring it sits down inside the selector then just lightly push the replacement into place a light click all done. Marvellous!
A
Andrew63
C250 estate 2016
Just looked at the eBay picture yes that’s the one I was a bit worried that the curve wouldn’t match it does!
Ming 666
2016 C350E
I guess it's only £7 so I won't lose much if it doesn't fit! the spring and the little black thingy on top of the spring are still there under the broken switch
Thanks for the info
A
Andrew63
C250 estate 2016
Glad to be of help
Ming 666
2016 C350E
Just to update, it fitted fine, just a push fit. However there were bits of plastic from the old one in the mechanism that I couldn't see. They stopped it pushing home properly. i had to take the whole switch pack out to find them and remove them. Just a heads up for anyone else. if it doesn't click home easily that's probably why.
A
Andrew63
C250 estate 2016
  • #17
I did warn you of that
McDonald
Surrey
SL500 2004
Welcome Andrew63. Mostly, people arrive at the forum with a problem that baffles them. You've arrived with problem & solution in one package. Neat.
