Windscreen wiper arm disconnecting
MC220d
C220d Bluetec Amg line 2014 2.1
Hi All,
The windscreen arm keeps disconnecting on my car and I’m having to open the boot and click it back into place?
Will this need replacing or is it just missing a screw or something? From visually just looking at it, it doesn’t look like anything is missing
I’ve added a pic of where it disconnects
Thank you
Probably missing an E-clip.
If the pin has a groove in it that's where the clip fits.
Probably would do the job (if there's a groove).
MC220d
Thanks for the rapid reply guys. Was just going to post a link to:
https://x8r.co.uk/wiper-linkage-clips.html
I have attached the link disconnected? Does the pic help as I’m not sure which groove your referring to
mattkh
England
A160 W168 1999 1.6
Is it a one-wiper front screen or the rear wiper.
Wearsafoxhat
Sunny Hampshire by the sea
Looks like it’s had it to me... rusty joint, possibly seized at some point then been” un seized “ by someone less delicate..
two heavy duty ty- wraps may hold the ball and socket together and allow movement, until you can replace it.
Look on the various IPL sites such as 7zap to see if somethings missing (ie clip) which you could then order from MB. No point in ordering a pack of 10.
MC220d
Yeah it was front driver side wiper
Thanks for the help guys
The pack I linked to was £6 odd .... ;) OP could have used one & put the remaining 9 away for future use! :D:D
If a C Class's wiper linkage/motor is anything like Smart, MB will only sell it all as a single unit ££££££££s
MC220d
The link I bought didn’t fit so I’ve bought the linkage arm for £60 off a breaker. They included the motor aswell.
When it gets fitted, is it worthwhile to get the motor replaced at the same time as it has come with the linkage?
Or will it need programming if I do?
mattkh
England
A160 W168 1999 1.6
When do you expect to get it? If I am not too late, If I were you, I would leave the newly bought one as it is until you have tested that it works.
I doubt it if it will need any coding, it is only an electric motor.
mattkh
England
A160 W168 1999 1.6
Just as an experiment, use some cable ties on the old one while it is still on the car, and see how long the cable ties last.
MC220d
I have already got the part. Taking it to a garage tomorrow to fit.
One of the mechanics said something like it’s easier for them to fit the whole arm with the motor already connected?
