Wireless Headphones
steve.link
CARDIFF
2014 W222 S500, 2019 W213 E220
Just purchased a pair of genuine MB Cordless headphones (Part No: A222 820 1889) for the rear entertainment system on my W222 as the original one were missing when I bought the car. However they don't pair/connect with the car. Not much info on "google" but it seems they have to be coded at a Dealership?? Anyone has experience of this who could offer advice
Steve
Headhurts
Norwich, Norfolk
Mercedes GLC300 2021
No idea I’m afraid but I assume they are Bluetooth so should not be too difficult, Mercedes do like their coding though.
Robin
steve.link
CARDIFF
Robin
Robin - they are not Bluetooth. Operating instructions says "Wireless 2.4GHz ISM Band"
There will probably be a method of pairing them, with luck it will be in the manual for the rear ICE
steve.link
CARDIFF
Found this on You Tube - so, you guys with Xentry systems is it a 5 minute job?
steve.link
CARDIFF
Problem fixed! - There is a secret Dealer menu on COMAND where you just add the UID numbers of the accessories you want to pair to the car. Access the menu by highlighting "SYSTEM SETTINGS" and holding the Comand control knob to the left for about 10 seconds. Follow the photos to take you to the pairing menu. Took about 2/3 minutes after several hours of internet searching!
trekerboy
New Registration
'13 x166 GL550
Steve, thank you for posting this pairing process. I have been searching for this pairing process for my 2013 GL550 (x166) for a long time and didn't find anything until I came across your post. Can you explain how you determined the UID of the headphones you wanted to pair?
steve.link
CARDIFF
UID number should be on a sticker inside the headphones where the batteries are
ozy194
Registered
London
X166 GL350 2013
Hi, I have been having the same issue! I purchased some AKG P104 OEM headphones of eBay and not been able to get them working. What headphones do you have for you GL? Did you manage to get them paired?
DaniilT
New Registration
Gle63S
Hi Im got same issue on my GLE63s 2018 And Im can get in dealer menu .Can somebody help
oka2blc
W222
I cant find the UID number on my P 104 harmon karmom MB headset for pairing. Does anyone know? I can't pull the form off and it is not in the battery compartment
oka2blc
W222
oka2blc
W222
no I did not. I can get to the dealer service prompt but without the UID number I cant complete the process. Do you know where the UID numbers are located on the P-104 headsets.?
oka2blc
W222
no I did not. I can get to the dealer service prompt but without the UID number, I cant complete the process. Do you know where the UID numbers are located on the P-104 headsets.? The headset are the same as yours Harmon karmon P104s
el5al
New Registration
Gle 43 Amg
Hi I'm having the same issues with my newly bought headphones from ebay. The remote control works fine but I can't get to pair the headphones. Tried the dealer menu by pressing hang up 7+9 and the option to "add kleer device" was greyed out.
Any suggestions will be greatly appreciated.
oka2blc
W222
I figured it out my s550 is a 2017 the instructions in the service menu above are very similar you must find the Kleer selection in the service menu. My uid numbers were on a sticker under the headset foam of the earpiece with the power switch. The foam does pull off and can be replaced without issues. once you are in just add a new headset or remote then select the UID numbers one by one and they will load. It looks complicated but just take your time..No dealer is needed,, they probably charge hundreds to do this..
clk200
London
www.synergy-motors.com
w124 E320\E36
Just done this on a 2016 GLE, can’t be done in the engineering menu and has to be done via adaptations in the rear screens via Xentry.
Pana89
GL350
I have tried this in Xentry but every time I have added the UID number and press the tick ✔️ button to add the headphones, I get an error as shown in the photos.
What gives?
Has anyone else had this and if so is there something I’m missing?
What gives?
Have you cleared out the old ones?
There might be a limit as to how many can connect
Pana89
GL350
I can’t delete as my Xentry does not connect to the ecu when I press the ✔️
I get the following message:
‘The control unit has rejected the diagnosis service required by Xentry Diagnosis.’
‘Possible causes:
The requirements are not met.
The vehicle must be at a standstill
An unexpected error occurred’
