Wrong shift lever fitted
rich.g.williams
Cardiff, South Wales
C200 Kompressor Coupe 2003
finally today I removed the electronic shift lever from my 2004 C200 CDI
there are threads here about my transmission problem, that it always goes into 3rd gear limp mode
amazingly the electronic shift lever part number is A211 267 31 24 a part that's normally fitted to W211 E Class
does this explain my transmission fault?
or will I be wasting my money if I buy and fit the correct part?
Do you have the 2009 EPC
rich.g.williams
rich.g.williams
yes thanks I signed up for EPC, it is telling me that the correct part numbers are:-
A203 267 55 24 Previous
A209 267 03 24 Previous
A203 267 90 24 Current
rich.g.williams
rich.g.williams
Sam,
the wrong part was fitted the A211 267 31 24 seems to be for W211 E Class as far as I can see from EPC
the transmission never worked properly since I had the car (always going into 3rd gear limp mode) soon after taking off
I think then you are on to something, lets face it the fault is odd
Cole@MBS
www.mbssouthampton.co.uk
I have a Selector module from a 220cdi at work, its 2nd hand, but if the part numbers match, i would be happy to send it to you, at your cost!!
At least you could try it and see, if it cured it then we can talk about you buying the selector, if it don't cure it, send it back!!!
Cant be any fairer than that!!
rich.g.williams
rich.g.williams
OK thanks Sam I would like to take you up on your kind offer.
I will email you my address etc.
dieselman
A diesel
I've not read any posts on this but what codes does the star test give. An incorrect speed sensor signal will cause 3rd gear limp mode as by then the ECU detects enough gearbox slippage/overdriving.
Cole@MBS
Let me first check that the selector i have at work is the "correct" part number!!
Malc, remind me when you get to us in the morning, my memory is getting worse!!
Will get it in the post by the weekend Rich if the part numbers are a match!!!
rich.g.williams
rich.g.williams
Sam,
OK please check it, I have sent an email to you and included my VIN.
Maybe you can confirm with EPC because it is saying following which I don't understand:-
008 CAUTION UP TO IDENT: A 021086, F 010264 ORDER GEARSHIFT LEVER* AS FOR VEHICLE EQUIPMENT LEVEL
429 THEFT-RELEVANT PART, WHEN ORDERING STATE VEHICLE IDENTIFICATION NUMBER
PS It is a Tiptronic
Cole@MBS
Thats a standard message with most things on epc, got your e,mail Rich, will check in the morning Sir!!
xavierx
2004 W211 E320 CDi
"429 THEFT-RELEVANT PART, WHEN ORDERING STATE VEHICLE IDENTIFICATION NUMBER "
Doesn't this mean this is a part that requires coding to the EIS system?
6
6pot
it can mean it will be coded at the factory, to a specific vehicle chassis number. It could also mean the factory just want to track it
rich.g.williams
rich.g.williams
can anybody say if the tiptronic shift lever from an E Class will work on a C Class please?
Tel: 020 8863 9233
