Yaw rate sensor location on C43
car2tref
Essex
C43 AMG in Black;all these gone-Ford Focus 1.8tdi,Mitsi Evo5,SkylineGTR33 670BHP@wheels,BMW M5
Yaw Rate sensor, anyone know where it's located on the C43 AMG 1998 as I need the part number off it? The usual ABS lights etc...
One grage said it's under the rear seat, another said under Auto gear lever area!!
C
car2tref
Essex
Thanks Television , will peruse and update if I get anywhere!
C
car2tref
Essex
Ineresting
Unfortunately no pointers to location but v. good start, any techies out there?
I thought it was under the rear seat, or is that a 203 im thinking about??
C
car2tref
Essex
O.K. I'll try and access the seat area tomorrow.
bigasotonuk
Southampton UK
C43/55 AMG 1999 / C230K 1997
Though I can,t tell you where it is but I can tell you its not under the the rear seat squab, so yes SAM i think you are talking 203.
Thinking about the function of the YAW rate sensor, I would think it would be where you mentioned, somewhere around the gear shift as I would think it would need to be on the centre line of the vehicle.
As the rear seat seems to of been mentioned by others you could try under the plastic cover immediatly behind the rear seat, access to which can be gainned from inside the boot.
I was banking on you knowing this one Andy, the way you know your C43:D
bigasotonuk
Southampton UK
I thought I would post and say that it was,nt under the seat squab as I have removred this on mine a few times and knew there is nothing electrical under there, but if i recall correctly there are several control units, behind the rear seat in the vicinity of the battery, i,ll be installing the headlight levelling loom soon so i,ll be trying to identify many more items namely in the passenger side footwell area.
C
car2tref
Essex
Unfortunately did not get an opportunity to get this done today as the wife and daughter needed to be driven to another part of Essex for their all day shop!!
I will check the boot area and look for it that way, thanks again particular inbigasotonuk, the cars only done 76k miles and all stamps in the service book but seems to be quite common acros MB!!!
C
car2tref
Essex
Havent had time to look in the past few days but will try today- my indie said he would ring me back with a part number but as yet - no phone call!!!
Two breakers I rang insist on a part number as they say there are 5 diff. ones!!!!
mbzachs
Hello everyone. First time posting here but just wanted to say this is a great forum and can save everyone a TON of money.
So here is my situation. I have a malfunctioning Yaw Rate Sensor that is randomly engaging my brakes while driving. I pulled the codes and everything is pointing toward the sensor. The rub here is that the sensor is $800. I was told by a tech that if i remove the sensor the system will simply disengage and I wont have TCS or ESP/BAS. The ABS will be left in tact.
I noticed that someone posted that the location of the Yaw Rate Sensor is under the passenger seat (front). I just wanted to confirm, has anyone ever replaced this part DIY?
Thanks again everyone!
hello, knowing what car you have would help :D
the sensor is mounted in the boot (errr, trunk?). forward of the spare wheel well you will see a large plastic cover - the full width of the boot space. remove this cover to expose the yaw rate and lateral acceleration sensors.
mbzachs
Thank you so much for your help! If i was in the UK i would buy you a beer! I have attached a pic of the boot...is the box i pointed at the Yaw Rate Sensor?
i think that one is the latt accel sensor. the yaw rate is to the left, small size, in plated metal clamp.
www.ckinsurance.co.uk
