2012MY C63 AMG Perf Pack dilemma
Rotorhead500
Rotorhead500
Very South Devon
Used to have a C63...
  • #42
Can you not simply jack the rear end up, get both wheels off the ground and spin one wheel. If normal diff the other wheel will spin the other way, if LSD both wheels spin the same way (I think that's the right way round!).
In theory you're right Peter, but in practice different diff types (clutch pack, which I think is the AMG type as OE, or helical cut gears as per Quaife), behave differently... I'm told.
Also, the LSD normally needs to be loaded before it locks up to any degree.
Done the above test, the wheels spin in opposite directions but 2 dealers are saying it has one, 1 dealer saying not! :confused:
V6Matty
Newark, Nottinghamshire
how much is it to replace the diff oil if it is an LSD? could be worth taking it to Acid anyway take a look inside and take it from there?
Rotorhead500
Rotorhead500
Very South Devon
  • #44
That could be a good plan Matt. At least I'll know the oil is fresh... if I have a LSD. :neutral:
Rotorhead500
Rotorhead500
Very South Devon
  • #45
Well, the saga continues! Supplying dealer has sent me his spec sheet for the car - which now lists it as having P30 (no change there), but describes that as Performance Pack Plus! (The "Plus" wasnt in evidence previously).
Has offered to take the car in to test it... as and when I can get across there!!!
toby1
West Berkshire
The P30 AMG Performance Package includes:
- AMG Limited Slip Differential
- AMG Compound Braking System
- AMG Track-Calibrated Suspension - stiffer springs
- AMG Leather/Alcantara Performance Steering Wheel
- Top Speed: 174 mph
P31 is PP+ which does NOT have the LSD as standard
Standard C63 had 457bhp, electronic ESP that was managed by the brakes and a decent standard spec. There are many cost options available though.
Early Performance Package (not Plus) cars had regular 457bhp lump, red calipers and 2 piece Ali/Steel composite discs, carbon boot spoiler, stiffer suspension and friction plate LSD. Again, plenty of options if you felt flush.
Then PP-Plus came along in 2009 (?), both pre and post FL, and that had 487bhp engine with SLS internals, suede / alcantara wheel, carbon boot lip, red calipers with single piece Ali/Steel composite disks, additional interior options. LSD and AMG suspension was a cost option.
JBell
Torquey
C350 CDi Estate (GAD Edition)
Well if it is listed with PPP then they had better make sure it has it or rectify and retro fit
daveenty
The Frozen North :(
2019 AMG S Class Coupe
Toby has it spot on up there. ^^^
PP is Option P30, whereas PPP is P31, with LSD as an option. :(
Need to see the build sheet which should have option 471 on it if it has a diff...
whitenemesis
CLS55 AMG '05
Just ran your VIN through EPC and it shows SA code 923 - Increased engine output but no SA code 471 - Mechanical locking Differential
Also looking at the rear axle parts info for your VIN the diff listed is not valid for SA 471 - Locking diff.
Going on what I've found I would, sadly, say you do not have a LSD
More than happy to be proved wrong though!..
daveenty
The Frozen North :(
I'm the same Peter, gutted for the OP really.
It's a shame that MB don't make it obvious, in that PP/PPP ought really to have LSD as standard. I believe that this wasn't an option on the earlier cars with PP, and they were all fitted with it, though even so, I would expect the dealer to know what they're selling instead of assuming.
toby1
West Berkshire
Yep, 471 is the one you want regardless of P30/P31 option.
whitenemesis
CLS55 AMG '05
The confusing part is the datacard also shows the car having SA code P30 - AMG PERFORMANCE PACKAGE ....
Options offered as standard within a package don't always appear listed separately but the rear axle parts breakdown definitely shows the diff to be non LSD
Rotorhead500
Rotorhead500
Very South Devon
  • #53
Gents, thanks for all your help on this!
I thought I'd got my head around these packages and respective MY intros, prior to purchase!
The fact that one minute they're saying it's the Performance Package, the next Performance Package Plus, has baffled me even more!
Certainly from the 2 data cards I've been shown, there is no Option U471 that is apparent. Even more befuddling then, that 2 dealers are confident that the LSD oil was changed early doors...!
whitenemesis
CLS55 AMG '05
Diff oil has been done on my CLS, beautiful blue colour!
C350Carl
Middle East
BMW 740Ld xDrive
All 3 :D
Just kidding. I hope you get it sorted soon mate.
V6Matty
Drill a hole in the diff light the oil that comes out on fire and then do a number 11 across the front of the supplying dealers forecourt, should get you some attention I'd have thought??? :rolleyes:
C350Carl
Middle East
BMW 740Ld xDrive
Or drive it through the front of the showroom and blame it on the lack of the diff... ;)
