Clean and polish
C350Carl
Middle East
BMW 740Ld xDrive
You would probably be better using Megs Scratch-X
Spot about the size of a pea on a microfibre cloth. Rub in a circular motion with medium pressure. Then buff off with a dry clean microfibre.
Capra
Capra
Gloucestershire
W204 2013 C350 CDI Pan roof
  • #42
Thanks Carl, could I just do the spots with this or would I have to do the whole car? I could then do the whole car with the anti swirl polish.
C350Carl
Middle East
BMW 740Ld xDrive
Just do the spots with it.
You will have to reapply any wax/sealant over the top as it will remove it.
You can usually get it in halfrauds.
I’ve never used Megs Swirl Remover so cant comment on how good/bad it would/wouldn’t be.
Capra
Capra
Gloucestershire
  • #44
Excellent, I have the all the other products to apply anyway so that will be ok. Cheers
Capra
Capra
Gloucestershire
  • #45
Hello again, I decided to pick that entry level DA. With this as I only have the single pad, can I only use this to work the scratches out? Or could I use the same pad to apply all of the layers of different polishes/finishes. Also, does it matter too much which speed the DA is on?
At least I don't have much roof to worry about.
Capra
Capra
Gloucestershire
  • #46
It is too early to use the jet wash and DA polisher?
Capra
Capra
Gloucestershire
  • #48
We're not popping round to each other for tea, but we get on lol.
John Laidlaw
Wirral
Land Rover Discovery 4
I start at 8 on a Saturday not a Sunday though
Capra
Capra
Gloucestershire
  • #52
Clay bar done.....knackered!!
Capra
Capra
Gloucestershire
  • #53
On off rain, I'm applying a compound at the moment and as I'm buffing off I'm getting a fine rain, will this matter in between coats of polish/wax/lacquer?
Capra
Capra
Gloucestershire
  • #56
Hi Wighty, slight delay it tool longer than anticipated!! God that was hard.
Bet you had fun though :D . I bet you are pleased with the results as well
daibevan
Alltwen, Pontardawe
W203 C200 Kompressor Elegance SE 2006 Tanzanite Blue with cream interior
It will be easier next time as you have done all the hard work. Maintenance is the key as in all things car. Pics please.
Capra
Capra
Gloucestershire
  • #60
Some pics before.
