Flyinspanner
- Aug 8, 2010
- Location
- Ruislip
- CLK320-A209 (sold CL500 & W168)
I get that not much may drain out, but wondered if ‘heavy bits’ would remain in bottom not necessarily picked up by pump? just one of those idle ‘what if’ - I realise the only 100% way would be drain then drop sump pan to really look!We need this tested so...I volunteer you.
1 Use a pump to drain as much as you can, then,
2 Jack up car, undo sump plug and tell us what happens next.
