Engine Oil Extraction via dipstick tube ?
Flyinspanner
Ruislip
We need this tested so...I volunteer you.
1 Use a pump to drain as much as you can, then,
2 Jack up car, undo sump plug and tell us what happens next.
I get that not much may drain out, but wondered if ‘heavy bits’ would remain in bottom not necessarily picked up by pump? :) just one of those idle ‘what if’ - I realise the only 100% way would be drain then drop sump pan to really look!
Naraic
2005 CL500.
A magnet would catch them...even if attached on the outside of the sump.
KeithJG
Dover, Kent
C320CDI Sport Edition S203 2006 V6 7g
Me being "old school" i do not like ALL modern methods they are designed to trick or earn others money!
It has all been done before so i still prefer to take the sump nut out and let the oil woosh out with the force of 8 litres behind it and any sludge or crap that may come with it. The suction method by MB is too slow to do any good?
This was also an article i read about a problem OM642 engine that had problems with engine bearings etc. and it was due to heavy sludge in the sump due to over use of the oil or infrequent changes?.........so is crap left in there???
http://www.benzworld.org/forums/general-mercedes-benz/1663766-om642-v6-diesel-engine-failure.html
Submariner1
Windsor Berkshire
CL500 2009 5.5
Yes, it's mainly how MB do it, you will get 95% of the oil out this way too.
My main dealer said they often Remove the drain plug, depends on the engine sump shape. And where the suction tube ends.
On the parts list used on a service for the 5.5L engine is a sump plug ... a few quid. And irrelevant to me, as I always get a pre agreed discount price on any service. Kinda price matched.
But tbh doing under 3000 miles per year. The oil still looks like golden syrup just before the service.
You can just about see the colour difference on the lower 5mm of the dipstick afterwards.
Submariner1
Windsor Berkshire
CL500 2009 5.5
Here's my routine for oil changes on my 129 (8 litre sump, 6 litre pump).
1. Warm up oil to make it easier to extract.
2. Insert tube and pump up pressure.
3. Check oil flowing and go inside house.
4. Put kettle on.
5. Come back out and once 4 litres has been extracted stop pump. Empty reservoir into suitable container.
6. Re-insert tube and start extraction again.
7. Go inside, make cup of coffee and find biscuits.
8. Come back out and wait till pump stops suckingoil. Start to consume coffee and biscuits during this time.
9. Start pouring first 4 litres of new oil in.
10. Wait till all drained into sump.
11. Drink more coffee and eat another biscuit.
12. Pour in remaining oil till dipstick says it is nearly at maximum.
13. Finish coffee.
14. Change filter (do this after finishing biscuits - old engine oil isn't a good dunking replacement for tea or coffee)
15. Run engine briefly.
16. Check oil level and top up as required.
17. Clean up, empty pump into suitable container.
18. Go inside for celebratory beer.
Interested in the order of work.
Sounds like you put in the new oil before changing the filter.
Any reason why you don't you drain out the dirty oil, then remove the old filer , replace with a new one and then put in the clean oil?
Yep. You can fill through the filter housing as demonstrated by Cole today when he did the A service on our r230 (amongst other work).
I found out today it primes the oil pump that way too.
mioba
Nottingham and Köln
Have just bought another CLK this time a 2008 CDi220 .
I appreciate it doesnt have a dipstick fitted but does have the tube obviously .
Is it possible to draw the engine oil from the dipstick tube or do I have to get my shorts dirty and get under the car .
Thanks in advance.
Without reading all the replies it's been covered to death.
Lord_Lucan
Bedfordshire, UK
No longer own a Mercedes Benz
It might be reading this with a headache but you remove the old oil, pour in the new oil, then remove the old filter. But then I don't get the comment about filling through the filter housing if it's still in place as you've not removed the old filter. Did I mention my head is hurting?
noonboots
R230 SL 500 2003 M113 5.0l
Not necessarily true on a new vehicle, and in that instance not necessarily terminal. :)
I wouldn't expect to be seeing machining debris or metal particles coming out of modern engines.Thats why the first service is at 12 months or 10000 miles. The days of running gently to bed in the engine are long gone. In the old handbooks it would say avoid hard acceleration and keep below 50mph for the first 500miles and then change the oil. It did indeed come out with metal particles in it.
Something found out yesterday. Before refilling remove filter, then refill half through oil filler cap then half through filter housing then refit filter
Pathfinder
Gourock
You should remove the filter before completing the draining/ sucking out of the old oil, as some will remain in there, held by vacuum until the lid is loosened. We always bath the new paper elements with new oil before fitting as this reduces the time for the filter to be primed on start up.
Msb
Clk500
Did exactly that on a friends car at mates garage, got as much out as poss by sucking oil out via dipstick tube and oil filter housing, when we dropped the sump plug out there was still a good half pint or so came out, this in my eyes is doing a shoddy job just sucking the oil out from the top, the sump plug needs to come out to do it properly
EmilysDad
Bury Lancs
ML350
Conversely, I removed the sump pan from my Smart after I'd sucked the oil out with a Pela and there was was next to nothing left in there ..... Smart Roadsters don't have a sump plug.
grahamcol
West Midlands
2001 SLK230, 2007 CLK220 CDI
B
But I suppose there would have been a few mins delay after using the pump - enough to allow more draining from the engine innards. I've managed to suck up more oil after initially sucking it dry, just by waiting a while. Ultimately I suppose it depends upon the shape of the sump and whether the suction pipe can really get to the bottom.
silestanix
London!
03' BMW 325Ci
4. Put kettle on.
13. Finish coffee.
LOL this is Exactly my oil change routine haha
Msb
Clk500
B
Agreed but in my experience from what i saw sump plug will be always getting dropped to ensure removal of as much oil as possible
Westheath
South London
Well ...........
Take off the cam covers and remove all the oil left in the top galley ways as well :)
If the vehicles regularly serviced then its not a problem imho
A lot of cars are "over serviced" to be honest,
unless the drained oil looks feels and smells like its in poor condition
i use the suction method, if I have any doubts about it I remove the sump plug
inspect anything remaining there suck out the filter housing, remove the cam covers and breather system,
turbo pipes and then if a problem with sludge or crusty burnt oil residue etc
I use an oil flush with new oil for an hour running and drain and refill with fresh oil again.
Its rare for me to find an engine crudded up due to lack of oil servicing or cheap oil usage, if i do its usually terminal because the owner/driver bought it in due to noises from engine.
Jim2
That's make sense.....in the days of cartridge filters, while the oil was draining from the sump, I would put some oil in the cartridge and let it soak through filter fabric. Never took long for the oil pressure light to go out on the dash. So next oil change after removing the filter from it's housing, I will put half a litre or so into it before dropping in the new filter. Rest of the oil will go in through the normal filler tube.
Westheath
South London
You might be amused by some Smart Car oil and filter change procedures.
I've seen some done by removing the oil filter and running the engine till no flow from the filter then refilling the oil and replacing the filter and called standard procedure
Time to walk away.
Submariner1
Windsor Berkshire
CL500 2009 5.5
Time to walk away.
So you are saying they drain the old oil out using the engine oil pump?
Definitely time to walk away from that garage. :(
I guess they can also save a bit more time, by running it until it stalls; hey then you dont even have to bother walking around to switch the engine off. :(
