Did a small mod today to the grille on the air box intake. Where i live we have a lot of tree's dropping seeds which would fall straight into the air box and likely would eventually block the water drain so i bought a sheet of 2mm square plastic netting which i cut to shape and placed over the grille. Time will tell if it stays in place and works, the netting doesn't restrict air flow so hopefully i have a cheap fix to the blocked drain issue.
Have you checked for damp under your carpet. If water is in the box it will be under the carpet unfortunately.
That sounds like a great idea. We have the same problem in our front garden. Do you have any pics of your mod?
Cheers
I think the "overflow" from box to inside the car is high up the box so Flowrider should be OK (I note that is the case).
I have not done the modification but I check the drains whenever I wash the car (I use copious amounts of water directed at the drains) and so far I have not had to clear the drains.......my car is garaged.
A drain is a drain and can be cleared like any other drain but avoiding blocked drains will save a lot of aggravation.
I note that Flowrider went in from the outflow which probably works best; the inflow is easily accessed with the bonnet in the vertical position and the box cover off........drain hole is nearest the wing.
Mic
Is that with the temp of the running of the engine..
Where is the sensor located Malcolm? If it's near the air intake box could the mod be shielding it from the cold ?
The external sensor is just behind the near left hand hand side, just by the side of the number plate if this one at fault, they often shoot way over 36
Could you see the old ones were dirty when you took them out?
Great saving so well done. I find it quite satisfying to do small jobs as it also gets you to know the car better.
Do you have a link to ones you bought?
For any one interested i have just changed my air cleaners in the SL. This is a simple 20 - 30 min job that if i can do it then anyone can. I bought the Bosch air cleaners on ebay for £10. My indy quoted just over £100 so i made a decent saving.
I to spend a bit of trawling the internet and find these bargains to buy and put away for the rainy days
