W221 Drive to workshop without changing gear
hmang
I'm getting this message and got difficult starting .
Thought ignition switch at first but not sure now .
It starts eventually but becoming a worry.
Any help gratefully received
Craiglxviii
Cambs UK
Engine, transmission, car year, location..?
Likely a gearbox module about to fail - it can then get stuck in park at some point and you will be stuck!
Get it on Star to be checked
Naraic
2005 CL500.
It's a 320cdi.
star
Reading
Smart + others :)
As above, get it checked and don't put it in park, even when you get to the garage, it may not come out. Could be the ESM.
H
hmang
Too late . It's showing that message and won't start now .
Yeah sorry folks it was a s320 cdi 2009
Anything I can do I'm stuck at south mimms services 130 miles from home
Call the AA or RAC for recovery . Good luck , but I don't know if I would have been 130 miles from home with a warning like that on the dash .
star
Reading
Smart + others :)
Not alot, when there stuck, they can be really stuck and in park too. We've had them stranded in the middle of our car park, either undo the prop or unbolt esm from side of box to get it out of park. Order new TRP part and code in. PITA.
The respected Indy Wayne Gates in North London is probably closest for Relay there .
H
hmang
Yeah happened this afternoon . I was already up here :(
Do you have recovery ?
H
hmang
Which new part ?
The selector gubbins on the side of the box ( intelligent servo or some such ) ?
Needs coding ?
Can I do that with my star or need dealer to do with internet connection to factory?
star
Reading
Smart + others :)
Which new part ?
Needs coding ?
Yes the ISM, get the faults read first before guessing, its a Theft Relevant Part (TRP) and will need coding. Don't think a copy star will do but not sure as we only have online star diagnostics. Need all the docs to order one if it is that.
H
hmang
So is a used ism a viable option or will the coding be a problem ?
Nope, new needed as coded to chassis number.....
Sorry I've been been on a flight so out of touch and just seen how this has escalated! What a bummer! Are AA coming? Or have come? Presume you're off to Wayne Gates with it
H
hmang
  • #20
I've got low 11.6v on the rear battery .
Could that be related ?
