W221 Drive to workshop without changing gear
H
hmang
  • #61
Right then .
Progress .
A clever person spent some time testing yesterday .
Seems my can lines are ok but there's a strange out out from the Ecu to the x30/21 voltage distributor .
He wants to test further .
In the meantime I'm
Looking into ecu repair possibilities .
Any one had ecu repaired ?
star
Reading
Smart + others :)
So your star still won't communicate with tcu or ism? Remove the connector under pass seat and open it up. The pcb fails.
H
hmang
  • #63
Thanks Star .
I might have got my designations mixed up but i think that one is the x 30 /30 that's what i meant in the previous post . It by the vent under the front passenger seat .
Block connector with 3 lots of can wires.
must say star instructions were a bit misleading , they tell you to test a particular plug which would intimate that they are in a particular socket in the block . Apparently they are not in any specific socket and it does not matter where they go in the block
It was probed quite extensively yesterday .
From what i understand there should be a difference in voltage between the high and low but should total 5 , and there was a discrepancy here
easy to check though , my new best friend has a spare one or i can pinch one from the missus wagon .......hopefully getting close .....
Steve@Avantgarde
Bristol/Somerset
Check the wiring diagram.
Most CAN buzz bars have 1 2 pin wiring plug which will have a different colour(s) to the rest. That is usually the supply line to the connector, the rest are feeds off to various other networks.
star
Reading
Smart + others :)
This is inside can connector
H
hmang
  • #67
sent the ecu away /
got a replacement one back all programmed with my settings .
plugged in turned on ..........yaay ......got gear selector lights that;s good .
programmed the new repaired ism ...........that all went in .............yaaaaay.
and it changes gear .....yaaaaaaaaay.
put every thing back together , and the engine runs .....................yaaaaaaaaaaaaaaay.
drove it 1" forward and 1" backwards .............yaaaaaaaaaaaaaaaaaaaay
had to go in for me tea.
Will give it a try tomorrow
I've got low 11.6v on the rear battery .
Could that be related ?
11.6 could be a sleeping CAN, or the battery could be old, it would normally at 10 days to the battery go to switch off or possible
Botus
S500/2010/500
sent the ecu away /
great news.... hope it behaves itself. Its been a bit of a nightmare for you
H
hmang
  • #70
yeah , ism went down and the ecu too ............chicken and egg job . dunno which went first .
doesn't matter now.
did the adaptation on my new recon torque converter, got a new mot
just done a couple hundred miles , so far so good :)
H
hmang
  • #71
doesn't matter now.
2000 miles further on . .............all ok
if any one's interested
JPAT in bristol repaired the torque converter
SOFTELECTRONIC in bulgaria did the ISM
ECU DOCTOR in Plymouth sorted the ecu ( exchange unit )
great service from all the above .
and
Thanks to all all the members on here who have offered help , suggestions and support .
it is much appreciated
thanks
phil
^ Great result and thanks for those recommendatons!
