why cant I buy just the brake light bulb
Status
Not open for further replies.
rf065
Grossbritannien
16w but it won't fit
It passed mot!
Show me where I can buy a bulb of that part number
Maybe someone swapped the ligh clusters before I bought the car
Sell it & buy an Audi or something, join their forum & give us a break. :rolleyes:
Russ
onefortheroad
uk.
http://my-car-bulbs.co.uk/mercedes-...00-230-250d-300-320-420-500-560-hid-2002-2005
Full list of the bulbs you require found here ^^^^^^^^^^↑^^^^^^^ even the facelift was fitted with the same bulbs. If 16w bulbs are fitted the prev keeper must of been a numpty and just threw any old bulbs in they had laid about. Check inside the cluster hole for 2 connections or one , its possible the wrong bulb types are fitted.
onefortheroad
uk.
Just a thought the bulb is 21/5 , did you just do a subtraction to end up with 16 ?
The reason people ask for a pic is to understand what the bulb looks like and the fitting its in. Not all of us have the same model and year of car as you.
mersum1es
Finland
Here...
Edit: and they are soldered in their places... other bulbs are 6W like you see one (indicator bulb) in behind
J
jasonyw
Banned
c180/1997/1.8;W211/2005/E200K
  • Banned
  • #27
It look like this but 16w http://my-car-bulbs.co.uk/r5w-207-sidelight-bulbs
Hey I know more than you guys then
I will post a photo next time I take out the tail light too many screws to undo at the moment
mersum1es
Finland
If they are as those they are not replaceable as they are long life xenon filled bulbs.
Yep, but next time there is blown one, I'll try replace one from my 'spare' cluster... ;)
Certainly worth a go. They're soldered in so if you have good soldering skills should be easy enough.
mersum1es
Finland
My pic above is taken from my broken (one bulb) light cluster
mersum1es
Finland
Please take a picture of the rear of you car an point out which bulb it is you need, not remove the cluster. As you say that part number doesn't exist meaning you probably have missed something maybe you have got a batch number and not a part number.
All bulbs are similar, code shown in my pic above.
Could be a great time to look at replacing the filament with an LED perhaps?
Put a load resistor across the back and it should keep the warnings at bay as well.
J
jasonyw
Banned
  • Banned
  • #36
Here...
yes, this is the one, so where can I get some without buying the whole cluster.
maybe I read PH16W as not 16 watts but 21 watts, am I right?
J
jasonyw
Banned
  • Banned
  • #37
it was 6 months ago since I undo the light cluster, it not soldered in as I managed to unscrew its out
triumphstag
Surrey, UK
SL 500 (2002) R230
Why do manufacturers do this.... For years standard bulbs have been absolutely fine and cheap as anything (I pay around 25p for standard filament 21w bulbs and around 30p for 21/5w)..... This is just complex crap for the sake of it.... and it obviously isn't that long life if the OPs has blown....
J
jasonyw
Banned
  • Banned
  • #40
Status
