why cant I buy just the brake light bulb
Status
Not open for further replies.
mersum1es
Finland
Could be a great time to look at replacing the filament with an LED perhaps?
Put a load resistor across the back and it should keep the warnings at bay as well.
Facelift W211 has full led clusters, but at least W219 pre-facelift needs an adapter to connector in order to avoid bulb error message, not sure about W211.
Naraic
2005 CL500.
Thank god that's over.
Naraic
2005 CL500.
You do have to wonder how it passed the MOT if the light wasn't working.
Its also been 6 months since the question was first posted. Six months with only one brake light :shock:
85 A 211 820 01 56 EXTERIOR LAMP ADDITIONAL STOP LIGHT; Replaced By: A2118201556
85 A 211 820 15 56 EXTERIOR LAMP ADDITIONAL STOP LIGHT
85 A 211 820 14 56 EXTERIOR LAMP ADDITIONAL STOP LIGHT
Thats the high level one Malcolm. He needs item 10.
2118200177?
2118200277?
Thanks you :D:D
10 A 211 820 01 77 LAMP SUPPORT LEFT 001
10 A 211 820 13 77 LAMP SUPPORT LEFT 001
10 A 211 820 02 77 LAMP SUPPORT RIGHT 001
10 A 211 820 14 77 LAMP SUPPORT RIGHT 001
10 A 211 820 03 77 LAMP SUPPORT AVANTEGARDE, LEFT 001
10 A 211 820 15 77 LAMP SUPPORT LEFT 001
10 A 211 820 04 77 LAMP SUPPORT AVANTEGARDE, RIGHT 001
10 A 211 820 16 77 LAMP SUPPORT RIGHT
Thanks you :D:D
Thanks Malcolm.
So in other words go to the dealer to get the right one if the number isn't on the board itself.
Thanks Malcolm.
Correct, the dealer will only supply one against his VIN number
EmilysDad
Bury Lancs
ML350
It does seem though that Mercedes can complicate a simple light cluster. The 'tracking' on my car's rear lights is integral to the cluster itself, the bulb goes into a seperate holder that has a bayonet/half turn fitting to the back of the cluster. Now one or two of my 'bulbs' don't make a proper contact onto the steel 'tracking' and need backing off very slightly to make them work because over the years they've arc'd slightly and there's a small burnt bit of 'tracking'. Remedy is to replace the complete cluster ...... no chance. My Vauxhalls have had a seperate bulb holder like those just linked to in the States so if they had the same arcing prblem it would have been a cheap easy fix.
DREAMER NO2
W124 2.6E M103 1989
Phew .I have just read this.Must say it was hard work for you guys..But i must say, that this is a bad idea .So if your out and about ,and the light bulb goes awol you can do nothing about it there and then .If thats safety i will eat my log book.
Yeah not the greatest idea....
L John
W204 C350 Petrol Elegance
It is a crazy idea but in MB's defence I think when a bulb such as this blows, a substitute is used, such as a rear fog light on the same side as the failed bulb?
EmilysDad
Bury Lancs
ML350
....So if your out and about ,and the light bulb goes awol you can do nothing about it there and then .If thats safety i will eat my log book.
It's the same though as on cars where you need to dismantle half of it to even get to the bulb. That's why places such as Halfords make a killing by charging a couple of quid to do it for you
jasonyw
Banned
c180/1997/1.8;W211/2005/E200K
  • Banned
  • #60
I didn't have any blown brake light just yet, that why it didn't fail MOT
I been proactive looking for a spare in case it get blown up
I have to start sourcing a light cluster with bulbs in it
will the dealer still supply me with a bulb if I quote A 211 820 01 77?
is this 16 or 21 watts to comply with the law?
Status
