1971 220SE (Automatic) won't accelerate
Mercrams
TW8
1971 220SE
Hello
I floor the accelerator but it still takes at least 5 seconds to go from 0 to 20MPH. From 20 to 50MPH it seems to be OK, but I feel it's still slow when compared to when it was working fine. From 50 to 60MPH it seem to take at least 10 seconds, all this albeit I still have floored the accelerator. The experience is similar to trying to accelerate from stall in 5th gear (manual car)
Any clues please
Thank you all
Stay safe
M
Mercrams
TW8
1971 220SE
Yes it changes gears when it hits 20MPH and so forth but it takes aforementioned times to change gears
M
Mercrams
TW8
1971 220SE
When did the componants on the ht side last get changed ? Like ht leads plugs distributor cap and rotor ?
Spark plugs were replaced a year ago but the rest haven't a clue;I have owned it for the past four years and probably driven about 4000 miles
M
Mercrams
TW8
1971 220SE
An update : I started the car, it starts and the moment I take my foot off the accelerator it stalls. Tried few times but still the same
Do you have a timing light to check ignition timing?
davemercedes
Glos
For probs like this it's worth getting the car to one of the MB Indys (Independents). We have a few such members on the forum and they are very well versed in all things MB and often give advice and guidance. They save people a lot of £olly not only through much more reasonable rates but due to their knowledge and experience.
If you add a location on your profile, somebody will be able to suggest who to contact.
M
Mercrams
TW8
1971 220SE
Thank you for your suggestion. I am in TW8
davemercedes
Glos
Guys: What Indy can be found near TW8 ?
robparker
Taunton
Oh that engine it could be something like the throttle linkage adjustment. Good luck
DREAMER NO2
W124 2.6E M103 1989
Well its your call; but if you ht system is shot,,or some parts in it then they will need replacing,, thats the first set of items they will replace .That will put the first £250 on the bill .. And this is a job you could do yourself for 1/2 the price . 90% of problems boil down to electrical ht faults. I thought this forum was to help owners do jobs themselves . And to save money .Once the ht side is bought up to scratch you could forget it for another 5 years or more.
davemercedes
Glos
The forum is here to offer whatever assistance members can offer.
Your suggestion is very valid but the OP initially asked for a garage or mechanic i.e. it looked as though he’d exhausted his own options.
IMO therefore, in the absence of another member/volunteer the best and potentially least costly suggestion was and still is to contact an Indy.
