1992 300SL Soft top problem
adamweal
New Registration
London
Mercedes 300SL
Hi there!
I have a 1992 Mercedes 300SL, with one major problem! it had an aftermarket alarm system intaled when we bought the car, the alarm system started to play up and we could not turn it off so we took it out and instaled a new one... so down to the point.. the electric soft top will not open anymore (it did before we removed the alarm) when we press the button down the light glows red and the roof locks into place how it should, when we pull the switch up the light flashes and the roof does nothing at all!
I have tried resetting the windows and the roll bar still with no luck!
Please help!
Thanks :D
konrad1511
Sheffield, England
CL500 year 2000, SL 350 2003, 450SLC 1976
soft top SL
hello,
how did you reset the electric windows and the rollover bar?
Turn the ignition switch to ignition on, raise each window in turn till closed, better on the slow lift then hold the switch for 5 seconds.
Raise and lower the roll bar and hold the switch again for 5 seconds when it is up
Al Blair1
Penicuik,Midlothian,Scotland
Sl 1992 300
soft top problem
I have a 300sl 1992, and i'm having problems putting the soft top away. The car goes through the cycle of the window's go down, the back end releases no problem, and then when the lid/door where the top is hidden will only raise 4 inches and stops. If i push the roof switch forward, it goes back down the roof comes back down no problem and clicks in securley and windows come back up to end the correct cycle. can anyone help, i'm anew user of this site and have posted this message twice now with no reply. thanks Alan
I did answer you post here
http://forums.mercedesclub.org.uk/showthread.php?t=111081
