2011 W221 S350 CDI intermittent non-starting issue
Joe B
2011 W221 S350 CDI
Hi all,
Was hoping someone on here can shed some light on an annoying intermittent non-starting issue we are experiencing on our 2011 W221 S350 CDI.
On the odd occasion the car won't start. All the lights on the dashboard come on but when you turn the key nothing happens, the car won't crank at all. When this occurs the yellow 'ESP inoperative' and 'run-flat tyre inoperative' messages come on. In addition to this, I have also noticed a curious pattern that everytime this fault occurs, the glow plug light doesn't illuminate when you attempt to start the car so much so that I now know that each time I attempt to start the car and the glow plug light comes on, the car will always start and exactly the same will happen vice versa i.e. if the glow plug doesn't come on at the starting phase then the car will not start.
We have replaced both starter relays in the fuse box located in the engine compartment but this hasn't helped. We've taken the car to a local garage with STAR but no faults were found relating to this issue. We have been advised that this may be an ECU fault or a fault with the EIS but was hoping some of the knowledgeable chaps on here can point us in the right direction instead of going down the route of attempting expensive guesswork repairs which is where we seem to be at the moment.
Any advice would be most appreciated.
Joe
Andy1986
Vito
There must be a fault code logged in vehicle when fault occurs. Perhaps another code scan else where joe
Joe B
2011 W221 S350 CDI
Thanks for your reply Andy.
I have attached copies of several diagnostics we carried out. The ones labelled as Merc Diagnostic 1 & Merc Diagnostic 2 we performed in house. Our chap didn't quite know which way to turn so I took it to a local garage for a second opinion, I have attached their diagnostic print out which is labelled as Autologic Merc. They reckon its the ECU which is at fault. Since then I went to another local garage who have STAR, unfortunately I don't have a copy of their report but in their opinion there were no fault codes showing relating to this fault. They think its the EIS that's faulty.
  • Merc Diagnostic 1.pdf
  • Merc Diagnostic 2.pdf
  • Autologic Merc.pdf
Andy1986
Vito
Looks like the communication fault between the modules is the main issue, or the module itself. Not sure if a battery reset when faults occurs might help find if connection issue or module/software. Could try another key if have one when fault present.
Shahaid siddique
W221 s350 2010
Hi all,
Joe
Hi Joe, I have the exact same fault on my 2010 s350 cdi. Iv changed the egr and also the ecu but the problem persist. Its a reap pain in the arse at times.
Did you manage to rectify your fault?
I'm looking forward to your response
Shahaid
bembo449
gainsborough , lincolnshire
so many things that could be at fault here , SHahaid have you had your car on STAR diagnostic machine
Shahaid siddique
W221 s350 2010
Yes I had, the garage advised me to get a new ecu as it was faulty, it would give different results at every scan. After the ecu replacement, the problem is still not cured.
barry jones
Warrington
2016, LWB W222 AMG Line S-Class S350d - W415 Citan Van too :)
Have you changed the glow plug relay and glow plugs? I had starting issues on both my W221's (06 plate and 10 plate) and both were fixed with changing relay and plugs... not too expensive to get replacements either. I think the last one I changed them on, I got the bits from Amazon... (all Bosch)
Shahaid siddique
W221 s350 2010
Did you have the same issue on both cars as mine? I did assume to change the glow plug relays and plugs. But my garage said its not that.
barry jones
Warrington
I had issues such as the car not starting, glow plug light staying on for ages and then still not starting. I tried charging the battery overnight (which did help a little) but the relay and plugs solved the starting issues on both cars.
firmasrl
W211 e270 1994
Same issue here ,noticed the pattern described with glow plug indicator. I also have this error on tester don’t know if it’s related. 21B752B9-E6B8-4914-9C47-B1CC23A2EAC6.jpeg 48025523-CBEC-49D2-B4AC-AC95695544BB.jpeg 468ADEF8-291A-40E7-B87E-4C08F939F14E.jpeg
Shahaid siddique
W221 s350 2010
Same issue here ,noticed the pattern described with glow plug indicator. I also have this error on tester don’t know if it’s related. View attachment 66176 View attachment 66178 View attachment 66177
Welcome @firmasr, your dash board looks exactly like mine. Unfortunately my car has completely stopped starting since Monday 1st March 2021, even when the glow light shows it won't start. Its Currently at Mercedes Specialist "London Code" let's see what happens. If you have luck with your let us know
firmasrl
W211 e270 1994
Thank you, mine from 03.03.21. I’m looking forward your results
You need proper diagnostics. OP's codes indicate an engine ECU comms problem:
1.U010087 Communication With The Engine Control Unit Has A
malfunction. The Message Is Missing.
SCM[MRM] - Steering Column Module(Chassis CAN Bus) 2 problems exist
1.D198 No CAN Message Was Received From Control Unit CDI
Obviously if the engine ecu has no comms with the rest of the system, it wont start the engine! His fault could have been engine ecu/relay in front sam/EIS
Your SPS code is for the power steering and is historic, so will not be the cause of the fault.
firmasrl
W211 e270 1994
Last night when i tried to started ( didn’t start) i got this errors
38388EA6-93A3-4A9C-A7C6-E115025B53A7.jpeg B66D0714-633F-4031-95D4-1A26CA38FFD7.jpeg 40F46F81-C7DD-47E1-A58D-5D7005BC62F4.jpeg FF8C480A-52D6-4B7D-9346-0AA093F27B60.jpeg 647ADD5C-7C7A-473E-A4C0-1840E754EF84.jpeg 1A1E0497-4439-432C-95F1-739943CAC419.jpeg F90D4078-0EB1-4F37-A95D-89A5E021CD86.jpeg 8BF7E5FA-BD65-4450-AC94-968FEA174F77.jpeg E3119B9F-07CF-41AF-83D4-1CBF89C67851.jpeg 0E9FC819-6C2D-4A72-80A6-2A42F2999412.jpeg
Botus
S500/2010/500
no comms from CGW (central gateway) is NOT good - that connects many systems to each other around the car
firmasrl
W211 e270 1994
Update:
- multiple errors related to CAN disappeared after i clean the connectors from engine bay ECU
- the starting problem is from main battery ( in my case anyway) , if i apply a battery jumper the car starts without any issues.
maybe this info can help others in my position
M2UBR
C230K
Update:
Hi did you ever sort the issues of non start on your car?
I have the same symptoms so any advice help would be appreciated
