270 CDI Head off, really stuck injector. Suggestions please!
Sponcom
Cirencester
C class/2002/270CDI
Hi All
I have a stuck injector, see picture!
The head of the injector had to be cut off in order to remove the cam cover and get to the head bolts.
It would not come out with an injector removal tool - wouldn't budge at all.
I have soaked it in carb cleaner for days and have had a 24" spanner on it and can't loosen it or rotate.
Does anyone have any suggestions before I attempt a last resort of drilling it out? I'm a little worried about doing this and damaging the head.
Many thanks
WG M-B
North west london
C63 Wagon in black
I had one once. Sent it to engineering company to be removed, and told me the head was scrap!!!!!
This was a 611 lump
Corned
East Midlands
2005 S211 E320CDI Avantgarde
If the head is off, can't you attempt to drift/knock it out from the combustion chamber end?
Edit, or is it still screwed down in its thread?
Sponcom
Cirencester
C class/2002/270CDI
Thanks for the reply. I've tried drifting it out but the injection end is very small and difficult to get a drift to stay. Maybe if I drill it a little I can get better purchase.
mersum1es
Finland
This won't be a big help, but I once read from finnish mb forum that they have used some kind of inductive/electric heater (or welding machine type?) to heat up the injector body, and then managed to pull it away. Of course problem is that if injector body is hotter than cylinder head, are the tolerances 'wrong way', but clearance should be so large that it doesn't matter. Instead the tar in between the hole and body will be more fluid and shouldn't be so adhesive.
Good luck.
Ian Parkin
Sheffield Yorkshire UK
w212 e250 CDi 2011 estate
warm the head up with a gas blowtorch and then stilsons
if you bring it to me i can mill it out...but prob to far for you ...sheffield..
Sponcom
Cirencester
C class/2002/270CDI
Thanks for the tips.
Sheffield is a little out of my way but thanks for the offer!
I'll try some stilsons and heating it this evening first.
kebo57
Lanc's
ml270
Hi get some heat in to the injector red hot
Turn head over and grip injector in a bench
vice a good one with good jaws, turn the head
by hand don't snap it of at this stage let it cool
down try again in the vice rotate clock & anticlockwise
Take it out of vice give the injector a whack with a
hammer as to knock it further in this could compress
the copper washer seal in the bottom of the hole
Your trying to move it but only minutely slowly slowly
catch a monkey, put it back in vice try rotating the head
with you hands, if it shears off it doesn't matter at
this stage as it will need to be machined out the head
will not be scrap, some one local could easily drill/bore/mill
it out.
I can machine it out I'm 165 miles from you
Get back to us ASAP
Kev
Edit the picture look like you have turned it slightly
if so turn it the other way
Sponcom
Cirencester
C class/2002/270CDI
Vice is a great idea and I just realised I've lost my Stilsons!
I'll give it a go and report back. If it doesn't work then it's off to the machine shop!
WG M-B
North west london
C63 Wagon in black
Do not warm the cylinder head up with a blow torch pleeeeeeeeease!!!!!!!!!
Applying heat directly to the injector will help although it goes against the laws of physics :confused:
Heat the injector while trying to turn it and you may have joy. Although I don't think so :(
But good luck!!!!
Sponcom
Cirencester
C class/2002/270CDI
I was a little worried about warping the head. I'll try a lot of heat on the injector first and try the vice method first and then off to find a machine shop near Cirencester to mill it out I expect!
Steve@Avantgarde
Bristol/Somerset
C43 AMG PP/NE, SLR McLaren Roadster, SL55 & C32AMG
As WG has said do not, in any circumstance apply blow torch heat to the head. You will definately wreck it then.
Im just wondering what the OP has tried to remove the injector so far because in all my years of working on MBs, I have never had a problem in removing injectors, even the most stubborn, some take more time, effort and skill than others but I have always removed them. If you have the right tools they should come out, eventually.
mersum1es
Finland
http://www.youtube.com/watch?v=0J2KxdN84RM
:shock::rolleyes::lol:
Corned
East Midlands
^ I was actually a little disappointed. I hoped they would come out of there like two bullets out of a rifle!
Steve@Avantgarde
Bristol/Somerset
Ive seen those monkeys on that video before, they obviously didnt hear of the special tool that works an absolute treat on A classes. I hope that kind of practice doesnt go on in any garage.
paul hayward
all MB sold..V70R now ;-)
Oh my word thats frightening:shock:.
:shock:..yep it sure is!! ... i would just take it to Cole at MBS and let them sort it..right people for the right jobs etc!!......
same as most things in life.... i know what im good at ..i also know what im bad at ...only do the things your better at!!! makes life less stressful!!:lol:
peterwhayward
grays essex
E240 classic est 2000 2.4
Yep thats why I dont do the washing and ironing;).
