badger_wazzala
What code readers or software is available for fault finding/diagnosis on a Merc?
For example: on my Audi's I've used VAGCOM.
Star/Xentry is the Mercedes factory one that reads everything.What code readers or software is available for fault finding/diagnosis on a Merc?
Mercedes are very clever, they don’t put all wiring and modules in unless it’s part of the build sheet, so if it wasn’t spec’d from new it won’t have it. Very different from VAG where everything is there you just have to activate itYeah it does look good.
Are any of these scanners capable of accessing and activating further functions/options?
Anyone have experience with the Autel MK808 as this looks the business for home use?
I've looked on youtube and it seems of high quality. I'd like to activate anything on my car that the dealer hasn't.
same as Bimmercode, I haven't bothered mind as I will never,ever be going near anything on the i8 (cowardly I know!)Mercedes are very clever, they don’t put all wiring and modules in unless it’s part of the build sheet, so if it wasn’t spec’d from new it won’t have it. Very different from VAG where everything is there you just have to activate it
iCarsoft MB v2.0 or if on a real budget the iCarsoft i980.
I use both on my R230. Not much is more complex than them.I need to buy a scanner to try and find an electrical fault in the airmatic system on my W220, would one of these be up to the job?
A mate of mine has bummercode for his M3 and it’s excellent software. The live info is great, especially when running high figures due to mods.same as Bimmercode, I haven't bothered mind as I will never,ever be going near anything on the i8 (cowardly I know!)![]()
Ah, something else I’ve learned already. Thanks for the info.Mercedes are very clever, they don’t put all wiring and modules in unless it’s part of the build sheet, so if it wasn’t spec’d from new it won’t have it. Very different from VAG where everything is there you just have to activate it
