mersum1es
Finland
One trick for debris; remove glow plug and tweak an air blow gun fit in the hole. Overpressure will blow debris out from injector hole or at least prevents then going in cylinder.
NBurns
NBurns
Sunny Hampshire by the sea
www.facebook.com
A180 CDI AVANTGARDE SE CVT,169.007, 2009
  • #24
You guys are in Woolston then. I’m in Gosport but car is in Hedge end currently.
Okay. Update. Have now used the injector cleaning kit for the first time. I felt like I had to use it twice through to get what I felt was a better result. However i am not impressed by what they claim it does. Photos to follow from the Samsung phone again shortly.
NBurns
NBurns
www.facebook.com
  • #25
Photos of newly cleaned out injector holes using a LASER Diesel Injector Seat Cleaner Set 14pc, Stock No. 6101.
20190622_142424.jpg 20190622_142431.jpg 20190622_142424.jpg 20190622_142431.jpg 20190622_142443.jpg 20190622_142451.jpg 20190622_142740.jpg 20190622_142747.jpg 20190622_143113.jpg 20190622_142813.jpg
Really, can’t see any clean fresh material there??
bob 6600
Audi S8 V10, S210 E320 CDI (R.I.P.)
Laser tools are very good however it seems you have purchased a cleaner rather than a seat cutter?
EXMERCTECH
Sutton,Surrey.
C320 V6 Diesel 2005
Laser 6101 looks like just a wire brush cleaner,
On second photo is that debris or a crack?.
I have a seat cutter if you need to borrow it.
I’ll be in Basingstoke next week.
Just need to find it.
That’s the Cutter not Basingstoke.
NBurns
NBurns
www.facebook.com
  • #32
It was a leaf. Oh okay. Thanks. When?
bob 6600
Oh. What do I need then?
What you bought is a cleaner, as said by @EXMERCTECH it's essentially a wire brush to clean the holes and seat. This is great if you don't need to cut them. If you want a seat cutter then something like this although please check it is correct for your car. Go gentle with it and cut the bare minimum
https://www.ebay.co.uk/itm/Laser-45...=1425606936040e6f035148b347d1b841de6452838eae
NBurns
NBurns
www.facebook.com
  • #34
mersum1es
Finland
I have cutter set but usually I use just a wooden stick with abrasive grind paper. Surface should be almost shining... in addition now couple of seats show clear marks of old copper seal location...
NBurns
NBurns
www.facebook.com
  • #37
Okay. Seat cutter has arrived. So got cracking immediately. To be honest I cannot see Any improvement at all. Photos to follow. Does not appear to be cutting any metal away at all.
Confused dot com!!!!
