Battery Warning Light Visit Workshop
Thanks Malcolm,
It was 13.8 when we tested it last week, so maybe it's just the software update required. Will book it in anyway next week.
That is all it can be,,, we had quite a few members that have had this update, 13.8 is perfect
bc100
South Devon
S205 C250 BluTec Estate 2014
Just to close my part of this thread, it was indeed the reg pack. I now have a UB reading of 12.2 at switch on and 14.2 with the engine running. Interestingly I did manage to start the car several times and drive short local trips in London with starting UB of 11.5, dropping to 10.9 on my last trip to the garage. Thanks again for the advice
ROBGOSTY
Manchester UK
2008 219 CLS 320
Hi bud, mine showing exact same symptoms, how much was your reg pack please ?
Cheers
Rob
Reg packs only cost about £20 but not suitable for all alternators
1104cobra
leyland lancashire uk
e calss 2005 220 cdi
halfords battery
You never know with batteries,,,many fail at 3 months and others 10 years.
The main thing is get a good make like Exide,Lucas,Varta, Bosch or banner,
House name batteries such as Halfords are a pain in the back side
The average life is 5 years
hi
i have just purchased e class 2005 220 cdi. every now and then red battery warning shows, on purchase of car had new alternator and new battery. i have change auxiliary battery.
when running volt reading 13.8 volt on both batteries.
only thing is the main battery is a halfords could this be my problem.
thanks
hi
thanks
This posses a hard question, these car were made to run on AGM batteries for 2005 I believe, the charging characteristics are very different for a AGM battery and a lead acid. It tells you in the handbook the type of battery that should be fitted.
1104cobra
hi thanks for reply.
I thought agm batteries are for stop start type cars more heavy duty Use.
is there anything you suggest do try next to clear error.
Your car should have an AGM battery, its possible that the battery inverter does not like the lead acid one as the charging is not the same, you will have to put the car on STAR to see what is wrong, if anything.
1104cobra
halfords battery
thanks for reply.
sorry don't know what is star.
think i need to change battery though.
The car should go onto STAR the diagnostic kit for Mercedes, any indie has one, and this would indicate the fault message. I would do that before replacing the battery.
1104cobra
thanks for reply battery not a fault. borrowed agm battery warning message still came on. going to have car checked with star.
The update in the soft ware would be worth having done.
1104cobra
merc found garage i purchased car from fitted wrong alternator. no red light anymore. glad still under warranty. thank you for your help.
GeorgeEclass
Scotland
E320sport
Can somebody help
My 320 was off the road for a couple of months. I took it out every two weeks. Had to jump start
Now it won't start, charged the battery and it turns over very healthy, got the red battery warning and "display fault"
Couldn't find the battery so put the charger straight onto the car overnight
Next option is get it towed to merc garage?
standman
New Registration
Hollywood, FL
2004 CLK 500
same issue with visit workshop light....
initially changed the alternator and the issue stopped. 3 weeks later same light issue... this time the battery 11.9v and the alternator 9.9v. Have the alternator replaced and battery was charged by mechanic ... car started however, the red visit workshop light was still there.. mechanic says the red light is still on and the battery isn't being charged.... anyone experience this before. He believes it's the fusable link or something... anyone know where to find this on a CLK 500 or it even exist on this model? or any advice on what to check for?
This should be just a pre fuse failed. Only the one battery on the 208/209
