bio fuel
mitie 1
herne kent
mercedes 2002 320
hi all hope you have been enjoying the sun just a quickie ive got a merc 320 diesal 2002 can i run it on bio fuel £1 a litre cheers .tom
Robbostanhill
Dartford, Kent, UK
E270 Estate 2003 and *Her* C220 W203
Only way to tell is to examine the specs for the bio diesel and compare it to the big companies product.
Changing the filters more regular will benefit too
turbopete
Spennymoor
2018 '18' Ford Edge tdci biturbo (sorry)
if you are talking about the 'home brewed' stuff from old chip fat, then no, not in a CDi engine, unless you want to go to the expense (and hassle) of twin tanks and uprated injectors, seals etc.
forecourt biodiesel (B5 or possibly B10 now) will be fine, but B100 is not recommended
Some guy on the internet
A few.
Lots of people run CDis on biodiesel. Twin tanks are generally used for WVO where dino is used until the engine is hot.
Steve@Avantgarde
Bristol/Somerset
C43 AMG PP/NE, SLR McLaren Roadster, SL55 & C32AMG
The old 613 will run up to 80% bio without many issues. Not sure I would go 100% though. I would start with a 30-70 mix with normal diesel and gradually increase it tank by tank and change the fuel filter once every 2 weeks until you are running 80%.
The mistake some people make is running 100% straight away
rjevon
Staffordshire
ML 270 CDi 2002
If the Bio is up to EN quality, even home brew can achieve this, then it will run without an issue.
I ran my ML270 CDi on GOOD quality bio for thousands of miles without an issue.
If you are unsure as the the quality of the fuel then dont use it.
Richard
