C180 Kompressor looses power on full-throttle
amosuro
London
C180 Kompressor/2003/1.8 AUTO
Hi everyone,
I have an issue with my C180 Kompressor (2003) Automatic 1.8.
Sometime last week, when I was approaching a slip road on the motorway, as soon as I started giving it some gas, it seemed to just loose power and almost go into a neutral state for a few seconds.
Once this happened, I can literally put my foot all the way down on the pedal and there's no power, the car just starts to slow down to about 40MPH...obviously you can imagine this is quite dangerous on a motorway.
But what is strange, is when I gradually put my foot on the accelerator it's absolutely fine, it only seems to be when I give it quite a bit of gas. I'm able to drive the car still, I just have to spend about a minute gradually increasing the speed to about 60MPH...which is an absolute pain!
I've had a mechanic drive it around, and he thinks it's something to do with the intercooler rad, saying that it might be blocked and that I should replace it. Intercooler rads are not cheap, and I'm hesistant to go out and pay that sort of money on a hunch.
I found this thread, and the guy seems to have exactly the same problem!
http://forums.mercedesclub.org.uk/showthread.php?t=89648
Unfortunately he didn't come back to say whether it was the hose or not.
Has anybody else experienced this problem? I'm thinking about trying the hose first, as it seems like the cheaper option, but I wonder if anybody has a diagram so that I can locate exactly which hose it is I'm looking for.
Thanks guys!
To suggest a blocked inter cooler is a very very odd suggestion, does this mechanic know Mercedes well?????
AMck
Newport
2007 E320cdi S211, SL320 2000(written off), Lotus Excel
A
amosuro
London
Well no, I don't think he does as he doesn't specialise in Mercedes cars.
Has anybody else had this issue?
Initially, I thought that the car was going into limp mode once it hit around 3000rpm, but it seems that I can pass 3000rpm provided that I gradually increase my speed. However, if I put my foot down (as if I'm coming onto a slip road) that's when it seems to have problems.
So this is odd...I can reach high speeds, but if I try to reach a high speed quickly that's when it cuts out. I'm completely lost with this...
You really need it checking properly, starting with fault codes and moving forwards from that point - there are a great many possibilities.
My guess is a fuel pressure fault, caused by a pattern fuel filter.
dswhitehouse
Naples, Italy
ML270 CDI/2002/2.7
I had a similar problem with my ML270 CDI. The power would suddenly cut back significantly under load, ie, overtaking or joining a motorway. Within a day it got to the stage where the ESP light would come on and the engine cut out (very scary on the motorway!). After rolling to a stop on the hard shoulder, the car would start and drive off normally without any problems and lights extinguished but the problem always occurred under load.
Despite the fact I changed it only 4 months previous, I decided to change the fuel filter as it was the cheapest in the list of possible candidates. Hey presto, it was cured. Next service I'm going to replace it with an genuine MB filter. I live in the South of Italy and fuel quality is abysmal here.
