dieselman
- Feb 10, 2001
- A diesel
This won't be the MAF or injectors as the engine has started.P1187-032 Rail pressure monitoring Control variation.
If not the pressure control valve it might be a blocked filter or leaking air in under load. Check the tank strainer and all filters/pipes.
Try running the engine from a can connected straight to the lift pump so bypassing all filters, strainer and pipes.
