C220 Estate interior Boot Panel removal
Tstc220
C220 w203 avantgarde estate 2004
Help,
Jst spent 3 hours trying to remove the panel to reconnect my rear wiper pipe as it popped off during th frost and courtesy of my wife, is now filling the boot panel.
Removed all the plastic screws/clips and can pull away the section round the boot release/lock, but as soon as i try to pull away the side sections, no joy stuck fast and dont want to force it and break.
Has nyone got any digrms photos or just an idea on how i can remove t trim to get the liner out an refit the pipe.
JBell
Torquey
C350 CDi Estate (GAD Edition)
If it's a W203 you have to lift them out then back, they are a bit tricky but you have to give them a yank
duncanh
Wiltshire
BMW 520d SE F10, formerly c220cdi estate (for 12.5 years and 345k miles), before that w124 and w210
I can't count how many times I have done this. I have had to reconnect the pipe many times, changed the wiiper motor and scraped the rust off under the rear numberplate plastic surround. All of the jobs require the trim to be removed.
You just have to be bold. Once the bottom trim section is off, you need to pull off the panel. There are two metal clips at the top of the panel that go into plastic, and I think about 4 plastic clips over the rest of the panel. (Maybe there should be more, I have probably lost a few over the years).
The side of the trim fits into slots on the trim under the window, so start from the bottom and pull the trim off, easing out the sides at the end.
I would be very surprised if you break anything, perhaps a plastic clip, but you probably don't need them all.
Best of luck!
I can send you the instructions to remove the rear door liner on a 203
T
Tstc220
If you could that would be great, then i can give it another crack.
I need an Email address, you can remove it in edit in a few mins
I have sent you more than you need, so just ignore what you do not want :D:D
T
Tstc220
Hi just got them, thanks for your help
T
Tstc220
Malcolm thanks for your help, those sheets were perfect. Got the panel off and reconnected the wiper hose. Though it is a bit daunting when you here there first catch pop out. Oh well brute strength won in the end. Thanks once again
It makes all the difference knowing just where the fixings are, pleased you did it ok :D:D
I have sent the tailgate liner instructions :D:D
paalv
203 200cdi
Perfect! Just what I hoped for! Thanks!!
HaroldB
Pontypool
C220 cdi 2002 2.2
Another Newbie Requires Help Please
Would it be possible to e-mail me the tailgate liner removal instructions please. I am sure the washer was working when I first had the car but since I filled the reservoir: no fluid at the rear. Thanks
I can do that with an email address, but is this not a problem where the pipe comes off in the rear corner or under the glovebox, it could well be in the tail gate,
All sent and you can edit out your address
8clopton
Suffolk
s203 /2004 /646 diesel
Another newbie needing help!
Hi television.
I know the thread is a bit old but are you still able to post instructions for removal of tailgate inner trim panel for S203?
Welcome to the forum :D:D
