C63 - Oil usage question
Jonathan Schofield
C43 Estate 2016
Actually I have two questions relating to oil:
Is 1 litre per 4000 miles within acceptable limits?
What temperature should oil be running at? Mine varies, when warmed up, between 95c and 105c in traffic whilst the coolant is fairly stable.
I have noticed that after running for around 20 minutes the water and oil temps drop quite a lot and then climb back up, is that normal?
Ah! That was three questions.
Jonathan
1 litre in 4k miles is nothing to worry about.
Oil temps seem fine. The coolant system has a thermostat so is regulated. The oil doesn't so can vary around a bit.
No idea why it would dip and rise.
Botus
S500/2010/500
could the oil cooler have a stat?
some cars do, another idea, which is kind of rev dependent (if I remember correctly) on a jag v12 only oil going past the relief valve goes through the oil cooler,
daveenty
The Frozen North :(
2019 AMG S Class Coupe
Seems perfectly acceptable to me as well, 1 Litre/1,000 miles is classed as acceptable by Mercedes on the M156 engine.
If anything I'd say that the oil temps are slightly on the cool side so you may need to try a bit harder. :D
John Laidlaw
Wirral
Land Rover Discovery 4
All looks fine to me, nothing to be concerned about....
Jonathan Schofield
Jonathan Schofield
C43 Estate 2016
Very rude of me to pose a question and then disappear, sorry.
Thanks for your messages of support, I was not too worried but I though it best to ask. I am intrigued about a thermostat for the oil system though, does it have one?
Daveenty: I would like to try harder, to get the temp up, but the roads are too busy and today on the one section where I can give it the beans there was a BMW X5 with blue lights on the roof in front of me the whole way!
Jonathan
could the
Yes it would appear it does:
That said from the clip it suggests it doesn't operate till a higher temperature than you're seeing.
T
The_Don
1l per 4K miles is perfectly normal
95-105 is the same as my 63, nothing to worry about.
www.ckinsurance.co.uk
