Cannot open roof "close boot separator" error
Yukko
Essex
A207 2011 E250
Hello
Tried to lower the roof yesterday but got a "close boot separator" error message. Looking in the boot, boot separator is stuck in a horizontal position. I'm sure it should be vertical. Quick investigation and somehow (!) the boot separator has popped off the right hand-side spindle thingy (?) and is now loose. Does anyone know how to put it back on?
Many Thanks
Dale Minton
SL55 AMG & BMW ALPINA B5 & ABARTH 595 Turismo
If you have a SL R230 or SLK the boot separator is supposed to be closed to allow the roof the open and close. You pull separator out toward to rear so it is fully extended and insert the male spigots that stick out either side at the rear of the separator into the female recesses that are fixed and attached to the inside of the boot area either side near the back - it should be obvious, as you click them in they push down on little angled switches. These micro-switches know the separator has been extended and inserted which will allow the roof the operate. Do you have an instruction manual? How long have you owned this car??
Yukko
Yukko
Essex
A207 2011 E250
Hello Dale - thanks for responding!
It's a E250 CDI A207 2011, had it for month and just getting used to it. I suspect it's a common problem and one that I am keen to rectify without too much pain or cost. I have attached some pictures to show where the boot separator should attached itself (it seems the other way round, the spigot is on the boot and should insert into the boot separator).
There are 2 bolts attaching spigot to car - should I undo these to remove, insert into boot separator then reassemble? Is it that easy?
Thanks and Regards
Dale Minton
I'm sorry but I can't help you on this this one, I am not familiar with this particular model and where the problem may lie, Hopefully someone else will pick up this thread.
Best
Dale.
Yukko
Yukko
Essex
A207 2011 E250
All sorted, removed spigot/spindle housing, inserted into boot separator then reassembled. Hood now working.
ellgeorgy
New Registration
e250 convertible 2012
sorry could you say that again? i am now facing this same issue with my e250 2012 convertible...
isnt it a case of just re-hooking something back onto the peg/pin? or is this a screwdriver/wrench kinda of job....?
Mike350
350 2004 3.7 V6
I’ve photo’d the left hand side of the roof separator on my SL, you’ll see that when it’s closed the male spigot engages with the female bracket which in turn houses the micro switch, which when properly engaged allows the roof to be lowered or raised accordingly. Make sure that both sides are completely clipped in, otherwise nothing will happen! Hope that helps
Mic
Oxfordshire
www.bennettgibbons.co.uk
Mike......for future reference it is the off side only that houses the micro switch.
Mic
Mike350
350 2004 3.7 V6
Thanks so much Mic, I had no idea, that’s what I like so much about the forum is the great advice you get and learn something new every day!
Gkinghorn
Bournemouth
E350 CDI Cabriolet - 2011
if the posts above dont help i can take a photo of my E Cab (2011) to show this i think ... let me know
AACoolJ
Gravesend
2004 CLK200 Cabriolet (Manual) & 2006 A-Class A150 5dr (Manual)
Hey guys. Getting the same "close boot separator" error on my 2004 CLK. Just found out about this group, so am catching up on the advice here, and will try out immediately after work! Thanks in advance, and great to be here!
Welcome buddy , but start a seperate thread as other new members do , you will get more response .
AACoolJ
Gravesend
Thanks Wighty. Will do that once I'm at home. Just a coincidence I discovered the group while Googling my roof issue. Really glad I found you guys. I notice you have a CLK as well. Awesome car!
Yes it is a lovely car . Stick some some pics of yours up when you introduce yourself , some of the simpler members on here really love a car pic.
X2-CLK
West Sussex
C 63 AMG, CLK 350 Sport Convertible
If the boot separator is fully pulled back and down and you're still getting the warning message then usually the cause is the gas strut not engaging the micro switch and pushing it back - it's on the left hand side in the boot
AACoolJ
Gravesend
Usually the gas strut not engaging the micro switch and pushing it back - it's on the left hand side in the boot
Just had a chance to get a quick look in the boot. turned out the separator was just not fully closed. must've been slightly pushed inwards when i picked up a friend at the airport over the weekend and he tried to push his bag in. he better not have broken anything!
Will gladly upload more pics (aside from the one on my avatar) when I get a chance. Thanks again for pointing me in the right direction!
Gozde Beyhan
E 250 AMG 2011
Hi there
I have a E 250 2011 with the same issue for a month.. probably my friend pushed her luggage too hard into the trunk. I am reading all these comments but the car part names are not familiar at all.. Is there anyway that I can have a video?
Gozde Beyhan
E 250 AMG 2011
Hi there
I have an E 250 2011 with the same issue for a month.. probably my friend pushed her luggage too hard into the trunk. I am reading all these comments but the car part names are not familiar at all.. Is there anyway that I can have a video?
