Change registration plate
Adam fox
Registered
A class 67 plate
image.jpg how do you unlock the plastic frame? To change the reg plate. I have no tools to unlock it.
400ixl
E250 AMG Sport Convertible
Usually it is just some push in clips at the bottom and then hinges up.
SmartAmg
2011 E class coupe 350 CDI
View attachment 47978 how do you unlock the plastic frame? To change the reg plate. I have no tools to unlock it.
Put an old credit card or similar down the plastic with the writing on move it till you can get finger tips in then gently pull it off . It's like mine only mine's Inchcape Southport. :)
As above it’s just clips in the bottom, some have clips on the side but yours just has the bottom. Don’t need special tools just a bit of force with something that won’t mark it. I’d use a trim tool but an old credit card should work.
