CLS500 is really underpowered! Why only 306BHP?
as400
South Coast.
W212 E350cdi
Can this thread be moved to Motoring Related Discussion?
Developer
S212 E63 S 5.5 biturbo
+1 with developer215 :D
You could give a whole new slant to our threads, though I should warn you, they get a bit blue at times - it's that Lizzy you know :lol:.
Naraic
2005 CL500.
The Kompressor engine with 3.2 capacity being faster than the V8 is as a result of what? Does it have a Turbo:confused:
I know you had a good answer above, but I thought I'd add to it.
Turbos and superchargers (kompressor) both do a similar job...they force more air into the engine to achieve more power.
The turbocharger does it by using exhaust gases to spin the compressor (for that is what it is), whereas the supercharger is attached to the crankshaft and this drives the compressor. Superchargers usually have a more instant effect, whereas turbos can suffer greater or lesser degrees of lag.
You could always make a poor man's compressor , just need a plastic tube into the cab from the air intake and blow hard in the tube when you need a boost, if short of wind, use an aerosol
tode
NW FRANCE
S350 btec 2011
This is the more modern version :
Mcobinad
Mcobinad
Milton Keynes
W219 Designo Black paint, R500 W251, CL600 W216
  • #149
I guess am accustomed to it. In my perspective this is definitely what makes it unique :lol:
