w204benz
- Sep 9, 2022
- 2012 C200CDI AMG Sport
I got a "top up coolant" warning while driving yesterday. Temperatures remained stable so by the time I got home I forgot about it. When I remembered to check a few hours later I found the expansion tank completely empty. It took all the coolant I had and a bit of DI water - about 4L to top up, although I heard a fair bit pouring out as I was doing so (I think the thermostat was still open - it holds on to the coolant while cold).
I found plenty of coolant on the left side of the engine, right up to the fuel filter housing, so I'm suspecting this has failed - I believe it's a common problem on the OM651.
Is there any other reason for the area where the housing connects to the engine to be covered in coolant? There are puddles of coolant in the housing's recesses, but with the engine running I don't know if the movement I'm seeing is the leak or just engine vibrations.
I'm fairly certain the area should be dry, but could the coolant be coming from somewhere else?
If someone can confirm that's most likely the problem, I'll order a new housing. Looks like it might be a possible DIY job. Has anyone done it, and more importantly is it as easy as it looks?
