Cooling and I phone queries 320 CLK CDI
Reginald
Cheltenham
www.prestigecarfinance.com
320 CDI CLK Coupe W209
Hi Folks
Just bought another lovely 320 CLK CDI ( see picture ) the last one went 4 years ago ...needed another as a third car. Anyhow the cooling is pathetic even with the fan on full and switched to air cond it hardly is blowing any cool let alone cold air ..ideas?
Also although it has an ancient-looking phone connect in the am rest is there anything I can buy to allow an i phone to run through the MB system ie via the steering wheel etc.
Thanks in advance
Charles
Hi and welcome.
The cooling issue could be anything from needing a regas (common) to a failed compressor. If it needs a regas it will need properly checking for leaks. Common leaks are compressor seals or condenser going rotten and getting a hole.
Bubble
Braintree
www.motacar.com
E350 Coupe CDI / Land-Rover Discovery 4 / Nissan Skyline 650bhp R.I.P.
If it's hardly blowing any air, then check that the pollen filter isn't blocked with leaf's etc.
Thaks Guys where is the pollen filter ..is it easy to remove?
If it’s the om642 engine same as my E class probably back right of the engine bay as you face the engine
Behind the blue windscreen wash reservoir filler , under the black plastic
Reginald
Reginald
Cheltenham
Guys found it and its look pretty black and had some leaves etc in it ....cleaned it but will order a new one...thanks
ps can the heater / cooler be run without one ?
Bubble
Braintree
www.motacar.com
Yes it can.
Reginald
Reginald
Cheltenham
Thanks, Bubble will try it tomorrow without it .
As you seem to be very knowledgeable can I ask a few more questions?
Can the diesel 320 engine be chipped ...would you recommend it?
What is the maximum size of tyres that can fitted with the current wheels on the car ?
thanks
thanks
It can be mapped , contact MSL ,
or GAD for advice . Where in London are you ?
Maximum tyre size to the current wheels is what you have already buddy
Bubble
Braintree
www.motacar.com
thanks
I had my CLK320 remapped by GAD and it was well worth it.
I changed the standard AMG wheels for some different aftermarket wheels, which were slightly wider and ran 275/35X18 on the rear and 245/40X18 on the front. I also used 5mm spacers on the rear!
I run the same size tyres on my E350 Coupe as well.
Reginald
Reginald
Cheltenham
Hi thanks again..
In Glos now left London about 3 years ago
Had a 350 AMG and hated it....those wheels are no good for Glos potholes....sold it after 4 weeks lost £1500 hey ho
Will call GAD
Hi thanks again..
Will call GAD
Change your username location buddy :D . It helps with members advice
Reginald
Reginald
Cheltenham
  • #19
If I could understand how to change it I would !
Have the tuning guy coming down tomorrow ....air filter and pollen filters ordered.
I have noticed it running on 245 rear and 225 front ...presume better to put 245 on th3 format as well....any make of tyre you guys recommend....thanks and stay safe
Srdl
Hampshire
GLC43 AMG 2018 (X253)
Click on your avatar on the top right, then select “Personal Details” and then edit the details for your car near the bottom. Then “Save Changes”
