Defect in key fob help
Rosy oli
Mercedes A class 1.5
Please help, my key fob for Mercedes A class 1.5 is playing up, it unlocks but doesn’t lock, I don’t know if it’s key battery or button or something else? Please advise what should I do??
Mike Smith
Reading
2019 C200 Estate AMG line plus
Try a new battery in the fob, easiest and cheapest first step.
CowleyStJames
Oxford
Mercedes-Benz E63s, Old knackered G wagon
Try the spare key. If it locks and unlocks on that, probably button fault. I'd suspect battery if neither worked on the first remote, but why should it unlock but not lock if battery faulty
One of the forum members is a key repairer "johnnysbc"
Hello and welcome
R
Rosy oli
Thank you, but unlock button works and lock button doesn’t work can it be battery issue
Is the top of the lock button cracked or broken? If so moisture can get in and corrode the contacts.
R
Rosy oli
I only have one key fob and spare key from key fob works fine, I can close manually it’s lock button not functioning at all, do you recon it’s battery issue??
R
Rosy oli
Is the top of the unlock button cracked or broken? If so moisture can get in and corrode the contacts.
There is no such sign, it looks all good, any advise?
CowleyStJames
Oxford
No. I'd suspect micro switch inside key.
joderest
ML270 2003
as above, try a new battery and re sinc first, if that does not work then either key faulty, or control unit faulty.
Tel: 020 8863 9233
