Diamond Polished Wheel Refurbishment
spock500
Milton Keynes
300TD, 1998
Bit O/T but never mind,
Any thoughts on using copper grease on the bolts/hub?
The hub is very stiff due to the liberal coating of power coat after wheel refurb, takes a fair wallop to get 'em off.
Bolts make that 'orrible cracking noise as they jarr with the alloy seat when being tightened/undone, it's a crack!! sounds like the bolts has snapped.
I have the blue silicone grease and moly but thought to check in first,.
Iain the gadget
Edenbridge, Kent
W208 230CLK W163 ML270cdi
Copper or silver slip is a good idea on the hub flanges as well as the bolts.
140CAER0TKH.jpg These are a good idea to for alloy wheels
spock500
Milton Keynes
300TD, 1998
Cheers will get some this week as all four corners coming off for new master cylinder -
Are those bottles of wine in your piccy?
If so do you drink them all first then your wheels look better, bit like beer goggles ;)
M80
Derbyshire
It's been said that copper grease on the bolt threads can reduce the friction when tightening and cause them to stretch with possible dangers.
I still apply a little around the bolt mating faces and around the hub.
Dosco
W211
I would avoid like the plague putting any form of grease/lubrication on the threads, between the wheel and hub faces yes but wheel bolt threads NO NO NO:shock:
spock500
Milton Keynes
300TD, 1998
I wire brushed the hubs clean which helped, anything to stop the corrosion setting in has to be a good thing, lot's of threads relating to wheel bolt seizure.
Most just changing wheels at home but if it was beside the road with a standard wrench you would be stuffed.
>Malcolm, you thanked two posters with opposing views :)
Thank and one removed :D:D
