If its a 642 engine with the 7g box then theres not even a dip stick tube!
How do you get the fluid in then, short of turning the car upside down and filling through the drainplug
Inside the sump is a tube about 2-3 inches long, you fill the sump using a pump into the drain hole, you put about 9 liters into it, put the sump plug back in and start the car,
You then put star on and watch the gearbox oil temp rise to 40-45, once there, you remove the drain plug and see how the fluid flows out, if its a smooth steady flow then that is fine, if it spits out the you add another liter and start again!!
Would you like me to send you the paper Malc
Good grief, what a performance.
