dip stick
362bkr
Plymouth
212 220cdi sport (nearly)
please can someone confirm that on my clk 320 cdi (v6) the dip stick is the red topped thing at the rear of the engine (passenger side) .many thanks.
Thats the auto box filler and dip tube
rf065
Grossbritannien
On the CLK220CDi the red is the engine oil & black is the auto.
Russ
362bkr
Plymouth
thanks thats great as always.i have just looked and its on minimun how much oil will i need to get to maximun roughly ? and what oil ? thanks again.
If its a 642 engine with the 7g box then theres not even a dip stick tube!
How do you get the fluid in then, short of turning the car upside down and filling through the drainplug:confused:
rpe2
Silchester
I have a fancy that's exactly how it is done (not upside down though). I think a gearbox version of colonic irrigation is required :shock:
I think that Cole posted to this effect before he left this forum.
well cole is still in the forum! to check and fill the the box level is done by filling and checking via the filler hole! its a work up and has to be done via star!!
Inside the sump is a tube about 2-3 inches long, you fill the sump using a pump into the drain hole, you put about 9 liters into it, put the sump plug back in and start the car,
You then put star on and watch the gearbox oil temp rise to 40-45, once there, you remove the drain plug and see how the fluid flows out, if its a smooth steady flow then that is fine, if it spits out the you add another liter and start again!!
Would you like me to send you the paper Malc:D
rpe2
Silchester
Sorry, I thought Cole had Resigned, or is he still viewing (if so, Hello Cole).
Any chance you could send me the paper?
Many thanks for the clarification.
rpe2
Silchester
Good grief, what a performance.
lulu
Kingsbere
They realised that not selling you the auto dipstick wasn't quite enough to stop DIY servicing on the 722.6XX gearboxes so, they introduced the above for the 7g gearboxes to foil us!
