Do these wheels/tyres fit? Read this post first!
Vix
New Registration
E220 Convertible/2016/2143
Help required please..... if you would be so kind
I have an E220 convertible, 2016 that currently has 19" alloys and very low profile tyres.. they are not really the best and the rear 255/30zR19 has been replaced twice already from the blasted potholes all over the roads up here in the Glens in Scotland.. this last time, I hadn't even done 100 miles between bursts!
Anyway, after spending time on the phone to Mercedes dealers today I have had no real luck in finding out if I can swap the wheels to 18" alloys, with what I hope can be 'not as low' profile tyres.. the last conversation ended with the chap telling me there was only one sort of wheel that I could use, as its not really the done thing to swap down? - he said an AMG twin spoke - but it was my choice if i swapped....
Could anyone please point me in the direction of where to find the information - please do bear in mind I'm a non-technical female!!!
Thanks so much, Vix :)
You can use any wheel from within the options list for your model and year with no problems.
Dropping down to 18s is not uncommon and there is no reason why you can't.
https://www.alloywheelsdirect.net/m...ys/f/18/amg-brabus-mercedes/all/all/price_asc
I wonder if the standard 17’s would fit from the W213?
AMGeed
Poole, Dorset
1998/2001 W210 E280 x2 SOLD 2004 W211 E55 SOLD, 2014 E63 Biturbo SOLD .S204 C180K
Madtutle3
Halifax, Nova Scotia, Canada
A250 / 2021
I am awaiting delivery of a 2021 A250 hatch 4-matic (W177). 2021s are simply a carry over of the 2020s.
My car will have the "Sport Brake Package". with 18 in. wheels. 7.5jx18 ET49 per this website:
https://www.wheel-size.com/
I would like to use minus size wheels for my winter tires, preferably 16 in. but 17 in. would do. The website lists available wheels as 6.5jx16 ET44 and 6.5jx17 ET44. (On the plus side they list 7.5jx19 ET49 and 8jx19 ET44).
Does anybody here know if the smaller wheels will clear the callipers on the "Sport Brake Package"?
AMGeed
Poole, Dorset
I doubt the 16" wheels would fit over them but 17" should be fine.
Your dealer should be able to confirm fitment of the 16" wheels.
Madtutle3
A250 / 2021
Unfortunately the service manager couldn't confirm fitment. Only that Sport Brakes were larger than standard brakes.
I haven't taken delivery of my car yet as it's a 2021 which is on order. 2021s are just a carry over of the 2020s. Delivery should be in Dec. / Jan. so I'm trying to line up winter wheels in advance.
marsdalebear
S205 C250 AMG Line
I have a 2016 S205 on 19" wheels. I am trying to source a temp spare but cannot find anything of the correct rolling diameter. Has anybody found a solution to this problem?
Madtutle3
A250 / 2021
There is a link on this website to contact the company if your vehicle is not listed.
https://modernspare.com/
Mr Badger
North West
E350
Will these winter tyres fit my 2016 C207 E350d
245/45R17 - 8J17ET48 the seller says they've been on a W212
Jimbo1959
Ayrshire
VW Scirocco, (current toy). The Quattro, E350 CDi Sport Coupe, now both gone.
I checked on a wheel and tyre size calculator for you and this is the report they presented based on the standard tyre sizes I have on the rear of my 2009 E350 CDi Sport C207, my car has the staggered set up though, (smaller on the front), I'm not sure about yours.
(My winter set up is 225/40/18 front and 235/40/18 rear).
Suspension :- 100% clear (leaves even more room than OE)
Fenders/wings :- 100% clear (leaves even more room than OE)
Wheelwells :- Will fill out the wheelwell by extra 21 mm. Make sure that you have enough room under the fender. If not, consider lower profiles or smaller rims.
Brakes :- Rim diameter is less than OE. Make sure that you have enough room for brakes inside the rim.
Scrub radius :- Negative scrub radius (about -7 mm). Scrub radius will be changed by -7 mm, this may affect the car's handling. Please check manufacturer recommendations. Please be aware that calculated value is approximate.
I hope this helps, personally, if I liked the wheels and the tyres were good, I'd ask the vendor to let me fit them to the car to check them out, that way you can't go wrong, they will either fit or will not.
This is the web site I use to check anything to do with wheels sizes I find it very good.
The link should take you directly to the report I spoke of. The only thing I can see as being an issue for you is the aspect ratio, if you got 40% or even 35% instead of 45's I think it would be a better fit on your car. I did a quick check and it improves things to go with either the 40's or 35's. The only thing to worry about then would be the brake caliper to rim distances.
A.J.
Norwich. UK
This is going to upset your speedometer reading. It will surely read faster than you are actually going due to the wheels turning faster :rolleyes: Illegal surely ? :confused:
Jimbo1959
Ayrshire
Andy gonnae stop calling me Shirley, please!
Report says this :-
When speedometer reads 60 km/h actual speed will be 64.1 km/h.
I don't know about the illegality or not tbh.
jookomak
W204 c250 cgi
Hi everyone!
I have a w204 2010 c250 cgi, currently on 17" amg alloys, tyres are 225/45 r17 on front, 245/40 r17 on the rear. I need to replace the tyres, and I was thinking about all-season tyres. Problem is, they usually don't come in the rear size.
The datasheet and online pages shows that the car can be fitted with all 4 225/45 r17 wheels. If I want to keep the rear wider, my options are 235/45, or 245/45. Would any of them fit? Or I just stick to the "all-4 the same" setup?
Tyres in question are the Goodyear vector 4seasons gen 3.
axelcls
Kettering
Mercedes w218 CLS63 AMG now gone, RR Velar
Hi everyone ! I’ve found some aftermarket wheels with winter tyres on and...the tyres are the right size, the only problem is with the rear wheels which are on a different ET. I’m running on my car 34.5-front and 48 on rear, what I found is 40 rear. Will be a problem ? Thank you
Abb
Mercedes
If everything else is the same (wheel width, tyre size) they will be fine. It just means they will stick out 8mm further than your current set up, which wont be a problem.
I have ran 15mm spacers before on my OEM set up of 19s on my 218 CLS with no issues, and currently run quite an aggressive (compared to stock) offset on my 20" wheels which is low 40s IIRC and that is on a 10.5j rear wheel.
axelcls
Kettering
I have ran 15mm spacers before on my OEM set up of 19s on my 218 CLS with no issues, and currently run quite an aggressive (compared to stock) offset on my 20" wheels which is low 30s IIRC and that is on a 10.5j rear wheel.
Thank you, I’ll go for them
Abb
Mercedes
Just double checked and realised I had put low 30's instead of low 40s! You will be fine with a ET 40 on a stock wheel. What design are the wheels or are they purely winters?
axelcls
Kettering
  • Like
Reactions: Abb
